BIKELAND > FORUMS > ZX-14.com > Thread: PC3 and which map? NEW TOPIC NEW POLL POST REPLY
Bawls
re-learning to ride
posted May 25, 2008 11:34 AM
PC3 and which map?
Here's a question for you guys. I am almost done with my deployment (4-5 days left). When i get home it should only be a couple of days before my re-enlistment bonus hits the bank and i'm going to be buying a pc-3 so that i can pull those pesky flies out of my bike. I'm running the pipes that qwick used to have on his bike. What map would you guys suggest i run until i can talk the wife into letting me spend the extra several hundred dollars to take my bike up to lee's cycles in san diego and have it dynoed and mapped. I'm going to guess that my pipes flow quite a bit more than a normal slip on since they're so short, but obviously i can't use a map for a full exhaust. I'm open to any suggestions. I don't believe that kevin ever had his bike mapped for no flies with the pipes, so I'm pretty sure that I'm going to have to get a map from someone on here if they don't mind sending me one.
Also, Morepowerracing.com has a low price internet guarantee on their parts so i should be able to get my PC3 for around 275 before taxes and with free shipping. Is this about normal, or can i find them cheaper somewhere else?
Thanks for the help,
Chad
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
MJ
posted May 27, 2008 06:07 AM        Edited By: MJ on 27 May 2008 07:09
Chad
If you want a rockin' flies out/slip-on map included with the pcIII for $285 contact Ivan at
http://www.ivansperformanceproducts.com/
....his flies out maps are truly unbelievable
The low and midrange will blow your mind
Bawls
re-learning to ride
posted May 27, 2008 06:44 AM
Thanks for the reply, I'm sure that I'll be getting in touch with him when i get back to san diego at the end of this week. My question is which slipon map should i get? I know that not all pipes are created equal, so i'm wondering which slipons flow the most air. That would probably be a good match for the pipes that i'm running.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
lowcel
Happy on 2 wheels.
posted May 27, 2008 07:07 AM
Contact Greg at www.hyperbikecenters.com. He has pciii's for $290, but I think I read somewhere that he is selling them for $260 this month. Anyway, he includes a free map pre-loaded with purchase and will be able to get it programmed for your setup.
2007 Z14 SE - Yoshimura TRC full race exhaust w/ carbon can - PCiii w/ map from HPC - Flies removed - Pipercross air filter - Speedohealer - Puig Double Bubble - Fender Eliminator - GPR Steering Damper - Puig Frame Sliders - HID's - Halo's
0.2505350112915 seconds processing time
