BIKELAND > FORUMS > ZX-14.com > Thread: front end has wicked shudder NEW TOPIC NEW POLL POST REPLY
zx14canada
posted April 24, 2008 04:16 AM
anyone encounter this problem ? when I break the front end is developing a wierd shudder feels like the head bearings are loose
posted April 24, 2008 04:25 AM
likely warped rotors
zx14canada
posted April 24, 2008 11:18 AM
would warped rorors cause the horm to hit the rad?
posted April 24, 2008 11:36 AM        Edited By: dubious on 24 Apr 2008 12:37
Sounds like a differnt issue now ....
no , lowered frt end and bottoming suspension would cause fender to push horn into rad
That happened to mine, so the horn got binned...
smeg is proactive and better than the tweety bird horn anyway though....
zx14canada
posted April 24, 2008 11:42 AM
I have not lowered it jiust normal everyday riding can feel it in the barss seem to shake back and forth
FIFTH
The Magnificent Bastard
posted April 24, 2008 11:47 AM        Edited By: FIFTH on 24 Apr 2008 14:20
Your not trying to use the helmet lock to pull the seat off, are you??? Sorry, just have to ask.....
Is it both handle bars shaking??? And have you checked your tires for uneven wear patterns??
posted April 24, 2008 01:08 PM
air in front tire 1 inch low
ZXLNT
posted April 24, 2008 02:00 PM
Warped rotors...
Bawls
re-learning to ride
posted April 24, 2008 02:20 PM
Loose nut behind the bars...
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
ghostman
posted April 24, 2008 03:06 PM
DDDDDAAAAAAAAAAAAAAAAMMMMMMMMMMNNNNNNNNN!!!!!!!!!!! LMAO!!!
I'm There Whether You See Me Or Not.
posted April 24, 2008 03:40 PM
That was an American zx14, not Canadian zx14 LMFAO
fury
posted April 24, 2008 04:07 PM
I love it!
fury
posted April 24, 2008 04:13 PM
Any oil leaking from the forks?
Did u get the bike used? Did the prev owner hammer the breaks (warped as mentioned)
Was it in an accident? horn shoved into the rad? (are we looking at another issue?)
Brake pads damaged? Pieces missing metal on metal? (squealing?)
Need all the feed back u can give us.
Air in brake lines? Cause brake fade and pulsing possibly...
FASTESTbusaAROUND
I eat Fish...
posted April 24, 2008 04:56 PM
Warped rotors...had them on my 06...feels like shit too...
FYYFF!!!
zx14canada
posted April 24, 2008 05:08 PM
Bike was never in accident had it since new 07 with 7000 km on it does not happen all the time just under heavy breaking. Just looking for what the problem could be could do with out the other smart ass comments thought this was a helpful site to look for info on.
FIFTH
something else you need to check is are the shock struts protruding equally through the triple trees?? I rode a bike that had them uneven and it rode like every bolt on it was loose, especially the front axle nut.....
zx14canada
posted April 24, 2008 05:10 PM
also there is no oil on the forks the fork seals look good and the break pads are still good no metal on metal noise
FASTESTbusaAROUND
I eat Fish...
posted April 24, 2008 05:25 PM
Warped rotors don't grind metal on metal....but you'd know if they're warped...you'd feel it in the brake lever and the bars on this bike. My 10r also had it...
FYYFF!!!
MJ
posted April 24, 2008 05:54 PM
Reading smart ass comments are half the reason I come here
The other half is to give them
Either your rotors are warped or your front tire is cupped/wore out. And you won't need the key to replace the front tire
FASTESTbusaAROUND
I eat Fish...
posted April 24, 2008 06:37 PM
I'm going with warped rotors; I'll put money on that -- been there, done that. I figgered out after a trashed the rotors on my 10R and my 06 14, that if you have to break anything in on these bikes, it's the brakes, not the engine. They need to seat properly before you apply severe pressure. I broke my 08 in right and the rotors are perfect now! Bad news is that Kaw doesn't warranty the rotors...ask me how I know...
FYYFF!!!
200hp_zx14
posted April 24, 2008 08:30 PM
Chances are its just air pressure in the front tire. I used to have a bad head shake problem on my old R1. Decelerating from about 65 to 45 with no hands on the bars would cause bad head shake. I took it to the dealer and Yamaha said that it wasn't a problem and doesn't need to be fixed. I bought a scott's damper to help with the problem. The head shake wouldn't be bad if I installed a new front tire. But after about 2 or 3 thousand miles it would cause uneven tire wear and the head shake would get worse as time went on. Two things seemed to help a lot with the problem and that was proper tire pressure and relatively new tires. If I swapped a front the same time I would swap a rear, I wouldn't have problems at all. And if I kept my hands on the bars during decleration, I wouldn't feel the shake.
Yamaha wouldn't fix it because they said it was inherent to the aggressive design and suspension geometery....Bastards!
207HP* '06 Candy Blue ZX-14
Some mods done
Best run - 10.19@137.40mph
ZXLNT
posted April 25, 2008 02:17 AM
I'm going with warped rotors; I'll put money on that -- been there, done that. I Bad news is that Kaw doesn't warranty the rotors...ask me how I know...
They warrantied mine. Its all in how your dealer presents it to Kaw...
fury
posted April 25, 2008 05:06 AM
Tire pressure easy to check.
After that "rotors as Steve stated"
With the above list completed you have done a good front end inspection.
No accident - nothing bent or damaged.
Take care.
posted April 26, 2008 09:54 AM
put some new pilot powers on there, my 14 is rock solid with them, the only other problem could be warped rotors (brake job time)
bulldogprostock
posted April 26, 2008 04:30 PM
Easy way to check the rotors, assuming you don't have a dail indicator, is to take a black marker and draw a line around the rotors and ride it down the street and apply the brakes. If you have a dotted line when your done your warped. Another possibility is glazed pads. My Buell XB12R with the perimeter brake set-up would do that and needed sanding every 3000 miles.
2001 Busa, 2008 ZX14R, K6 GSX1000R
0.24291896820068 seconds processing time
