BIKELAND > FORUMS > ZX-14.com > Thread: Running Hot NEW TOPIC NEW POLL POST REPLY
zx14_busakilla
posted April 20, 2008 04:59 AM
Running Hot
My fan stopped working last saturday the bike ran really hot ,took her to the shop tuesday the fan started working again, rode the bike twice since then in heavy traffic the fan worked good, not sure why they didnt do anything to it. Have anybody had this problem before?
jdzx14
posted April 20, 2008 05:14 AM
I havent had that problem myself but sounds like the fan motor stopped on a bad spot or burnt spot, kinda like a starter you have to tap on, or a window motor you have to hit to roll up, lol i have done that several times!! lol.If its under warranty make them fix it!
2007 Black ZX-14
fury
posted April 20, 2008 05:16 AM
Replace the fan if they did not repair anything.
Just as jdzx14 stated.
FASTESTbusaAROUND
I eat Fish...
posted April 20, 2008 06:02 AM
Ya, my 06 never had heat issues, but my 08 hits one bar below the top once in a while, making me suspect that it will overheat, left long enough in traffic...
FYYFF!!!
zx14_busakilla
posted April 20, 2008 07:13 AM
The other night in traffic it got to the bar below hot twice and the fan was working fine. Have anybody put two fans on one yet?
ninja14
posted April 20, 2008 07:40 AM
If it didn't overheat(flashing dash) then it was not really a problem - the bike is supposed to be hot.
I've riden around Leguna-Seca in July w/ 150* track temp - no flies - no PC and stock cans......still no overheating while sitting after running there......most of the 14's heat "problem" is imagined.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
vtxtc
posted April 20, 2008 08:07 AM
installed secondary fan
Best thing I have done to my ZX was to install a secondary fan. I purchased from spal/usa a 6.5 inch fan mounted very easy to radiator with there brackets and I epoxied on there clips. They also supply if desired the correct wiring harness which includes inline fuse and relay, system is 15 amp. I purchased seperatly a 15 amp waterproof toogle and mounted on those small fairing insert lips to right and left of the instruments drilling out one of the indentions. Now for the first time I have know worries of bike in traffic or hard rides.Cools bike down fast,I usually turn on when bike hits second to last bar. I think the whole install was about $150.00.
Sticks_n_Stones
posted April 20, 2008 10:44 AM        Edited By: Sticks_n_Stones on 20 Apr 2008 11:46
If I hear one more idiot stating that it's "imagined" I'm gonna trade them bikes! Just because your own bike, or bikes sold in Florida, don't have the issue doesnt mean its not an issue with other bikes! It could be as simple as a faulty gauge or sending unit, or thermostat not opening all the way, but I'm not friggin imagining it, nor are all the others who have experienced it!
My fan comes on when the gauge hits the middle bar, which I believe is where its supposed to. What we need is to have someone on a bike that doesnt register as running hot (like you) to use a infrared heat thermometer to register the heat in the center of the radiator when the fan comes on and/or JUST when it reaches the middle bar while idling. Then we can compare it to a "hot" 14 at the same time. I bet those stats would be in the same heat range. It's only AFTER those happen that the temp just seems to keep climbing as if nothing is attempting to coolit down. If we can deduce the problem, we can fix the problem.
Hell, I'll go friggin buy a damn infrared gun if one of you guys can post up your numbers for me to compare it too! i got a sneaking suspicion that its the thermostat, had numerous issues with cars thermostats not opening all the way in the past...
Any takers? Give me your numbers!!!
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted April 20, 2008 11:08 AM
Florida ZX14s don't overheat. Tonytooth, SmokinZX14, bigdtd, Mike, XstaticX, and I can all vouch for that :P
zx14_busakilla
posted April 20, 2008 12:06 PM
Im not imagining this guys. i was rideing down town look to see how fast i was going and all seen was the flashing dash pulled over in a parking lot .ANTIFREEZE was pouring from the bike the back tire was wet as fuck. We sat there for 2 hours until it cool off. Is this running hot or what ???
zx14_busakilla
posted April 20, 2008 12:24 PM
VTXTC thanks man i still need some more info. do you think the 7.5 will work ?,which bracket kit did you use ?and did you use the 12 volt
Sticks_n_Stones
posted April 20, 2008 12:45 PM
First thing first there skippy. If you were moving at any speed above 15mph and it wasnt 100+ degrees outside, you are going about it all wrong. Find out what caused that overheating first. Even my bike never spewed antifreeze, and I think I have one of the more problematic "heat issue" 14's onthis site.
You most likely have a bad thermostat, or bad water pump. Two words for you:
"Warranty Work". Now. Add the extra fan later after the bike is back to the way its supposed to be. Trust me, I've wasted money on the wrong fixes so damn many times it aint funny...
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
billeason
posted April 20, 2008 12:59 PM
Sticks-stones is close'' some of the 14s that run hot and boil over have a bad senser. I have had more then one here with this problem. It had me scratching my head trying to fiqure it out why some run hot and others don't. What i did was removed the senser from my bike that has never once run hot and installed it in one that was here that kept spitting coolant. This 14s fan come on and thats what fooled us but the fan wasn't consistent. I just said f%$k it and switched the sensers sure enough mine ran hot the customers did not. I have since replaced two more and one of the new off the self Kaw parts was bad also. That made three on one bike. I would have posted about this before but i thought this had been taken care of?? Bill.....
bill eason
zx14_busakilla
posted April 20, 2008 01:07 PM
Thanks Bill and Sticks for the help ,i need a thermostat or sesner pretty fast going to Deals Gap 23-25. wounder do they have them in stock at the local stealaship
billeason
posted April 20, 2008 01:18 PM
I'D be willing to bet money they have both. They know its a problem.... Bill...
bill eason
Smooth_G
posted April 20, 2008 01:20 PM
good show,,THANX FOR THE INFO,,i am doing the same thing with a right hand side zx14 concours fan,,,it gets a 120 here,,n i aint taking any chances ,,,i wished had known about that sooner,,,i would have went that route,,,,IT SEEMS AS THOUGH WE HAVE ALOT OF PEOPLE IN HERE THAT ARE IN DENIAL ABOUT THE HEATS ISSUES THE ZX 14 HAS,,,,,,,,
billeason
posted April 20, 2008 02:02 PM
I may have misspoke some when i said sticks was close,It may be a two fold problem. The 14's do run warm but most don't run hot. As far as denial the guys bikes that don't run hot can't report on it an have been wondering what the hell some of us have been talking about since the 14s came out. I may be wrong but i think from the start sticks remarked that this bike should have had two fans from the factory. I have to admit the senser is a weird failure,as may be the case with the thermostat. Also on the temps'' some of the bikes i have checked with infared with all bars showing the temp at the senser as best as i can read it there is about 212 degrees,so the gauge is not much better then the tach gauge for accuracey. Hope this helps you guys with the bikes that do run hot,and it can be fixed!! Bill...
bill eason
butta4hc
posted April 20, 2008 04:25 PM
I'm running hot as well. Thought it might be an issue because I had a fully Muzzy without a PC. I installed the PC, dropped in the appropriate map and still the same issue. I may just swap the sensor and stat just for peace of mind to know that they are new and supposedly in good working condition. Right now this is the LEAST of my problems though.
Butta
Hot Commodities MC
Paterson, NJ
2006 Black ZX-14 - Recall Frame Swap, Full Muzzy GP Exhaust, PCIII, BMC Race Filter, Flies Out, Braided Front Brake & Cutch Lines, Muzzy's Radiator Fan, Engine Ice Coolant, Frame Sliders, SubFrame Sliders, Puig Dark Smoke Windscreen, Powerbronze Hugger, Cox Radiator Guard, Unswitched Powerlet Outlet under seat, Switched Powerlet Outlet On Right Duct Panel, Intergrated Tail Light, HID lights high and low beam, Blue corner marker lights, Eclipse License Plate Blackout Kit, Black Pazzo Levers, Scorpio Alarm, Lojack Theft Recovery System, Rapid Transit Triple Tree Bag, Cortech Tank, Tail & Saddle Bags and the bragging rights for being "The Fastest 14 In The Country" for a few weeks when the 14 made it's debut here in the states.
  Ignore this member    Click here to visit butta4hc's homepage.
man00
posted April 20, 2008 04:39 PM
Are these really running hot or just running warm? IF the bike isn't puking coolant or back firing I don't think they are hot. And if the zx14 is like most bikes I wouldn't put much trust in the guages anyway. Maybe just ride and and pay less attention to the guages.
posted April 20, 2008 04:54 PM
all the bikes i had before were air cooled with no temp gauge, i wonder if a temp gauge is too much info for some worry warts
butta4hc
posted April 20, 2008 05:13 PM
all the bikes i had before were air cooled with no temp gauge, i wonder if a temp gauge is too much info for some worry warts[/quote
Lol. I rode my RC51 on a trip down the NJ turnpike this Saturday with my club. We hit the normal traffic around the normal area. I'm in full leathers on a v-twin in traffic when my bike starts to bake. It hit 260 then my warning light came on. I just hit the shoulder for about five miles or so to get the temp back down. I have a toggle button on my RC51's instrument cluster to watch either the temp, mileage or tripmeter. I can't tell you how many miles I have on it but I can tell you what my temps where for the entire trip, lol.
Butta
Hot Commodities MC
Paterson, NJ
kaw now
posted April 20, 2008 05:21 PM
I think we are looking at two separate issues here. Those who read the bars and interpret them as the engine running hot when in fact the engine is just warm as supposed to be. If in fact the bike pukes coolant when it is running then maybe there is a problem. Sounds like someone who is concerned about the temps should patch in a real temp gauge for a second opinion. The manual states the fan comes on at 203 degrees so that temp is not overheating.
ninja14
posted April 20, 2008 08:15 PM        Edited By: ninja14 on 20 Apr 2008 21:17
If the dash is not flashing it has not overheated........if it "feels" hot then maybe the rider needs to ride a bike that they can handle :-) ........maybe a cool running Vespa.....
I've put my bike through rough riding and temps well over 100* outside while moving slow and the leathers were hotter than the motor :-)
While it is a hot bike......very hot at times....I never got it to actually overheat according to the ECU other than a couple of times that were not normal conditions.
The bike is factory tuned to burn clean and function efficiently at a given temp - and it seems that the chosen temp is pretty high. A diff thermostat and tune could bring it down, but performance may suffer.
It takes 248* to get the "HIGH TEMP" warning..........that's freakin HOT
2006 Turbo ZX-14.
Sticks_n_Stones
posted April 20, 2008 09:19 PM
I've had the gauges flashing at me before from a overheat. Didn't lose any coolant but fuck my legs and thighs were roasting. First time I ever heard a bike LOUDLY ticking from heat! Let the fan run with the ignition off while I sprayed the ground under it with a service station water hose. (never spray a very hot engine/radiator with water. Just spray the ground all under the bike and it cools it off pretty quick).
I'm going to change out my sensor now, too. Which one is it? I read it has a couple of temp sensors...
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
ninja14
posted April 20, 2008 09:37 PM
The sensor is on the rear of the head............worth a shot if it is still a problem when the coolant is right and the pump is pushing it - you can take the cap off and when the bike is warming you will see the flow....rev the motor and watch.
Sensors tend to be expensive so it's smart to check everything first - amazing what air in the system can do.
2006 Turbo ZX-14.
0.23733401298523 seconds processing time
