BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy slipons map NEW TOPIC NEW POLL POST REPLY
Ranast
posted April 19, 2008 12:01 PM        Edited By: Ranast on 19 Apr 2008 13:06
Muzzy slipons map
Recently I purchased some Muzzy slipons and a Power Commander. I downloaded the correct map from the Dynojet site but after looking at it, it seems to want to lean out the mixture quite a bit in some areas (like -25% in spots).
My concern is that on a dyno the A/F mixture may be fine but at speed it could be too lean. Has anyone run the Muzzy slipon map (flies in)? If so what was your experience with the map (did your bike run well, too lean/rich etc.)?
FYI, I may go with a Brock setup at a later time but for now it is Muzzy.
Edit: One more piece of info is that I am at about 240 feet above sea level.
busajack5
Rocket lll
posted April 19, 2008 12:21 PM
Ranast, I have Muzzy slips but with the flys out and it seems to run perfect.Iam at 6.500 ft but that shouldn't matter because of the bikes barometric sensor. Give the flies out map a try just for the hell of it. I have run with just the slipons no PC and swear it ran better.
Jack
Ranast
posted April 19, 2008 09:09 PM
Thanks Jack, I will give it a try and see how she runs.
RobMuzzy
posted April 20, 2008 07:49 AM
Why dont you get the map from MUZZYS?
Ranast
posted April 20, 2008 08:25 AM        Edited By: Ranast on 20 Apr 2008 09:31
Actually I would love to. The problem is that I can't find a listing for maps on your site. Should I email tech support on your site for access to maps?
If maps are already listed on your site, I apologize but I am unable to locate them.
Edit: Actually I just found a map for an 08 stock no flies on the Muzzy site. That is the only map I could find. Do you have a map for an 07 slipons, flies in?
hardcoremass
Powerhouse
posted April 20, 2008 02:49 PM
Contact Murray at Muzzys, he should be happy to supply you the correct map for your mods.
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
Ranast
posted April 21, 2008 01:12 AM
Request sent. Thanks for the contact info!
0.26952195167542 seconds processing time
