BIKELAND > FORUMS > ZX-14.com > Thread: clutch NEW TOPIC NEW POLL POST REPLY
michaelball31
posted April 15, 2008 04:51 PM
clutch
Hey I changed my clutches today on my 14, When I put it all back together my clutch lever is stiff as hell.Has anyone had this problem before?I tried bleeding it and everything.Also I changed my front sprocket .Could I have done something to the slave cyclinder.I took the clutches out and reinstalled and still the same thing.Started with the smaller fiber and ended with the big one.Suppose to race this weekend so your suggestions would be appreciated.
smokinzx14
posted April 15, 2008 05:14 PM
Sounds like to have the clutches in right...... Were these oem clutches ? Did you use the same springs ? If you used aftermarket clutch pack it may have to much stack hight...
I would double check to sprocket cover and make sure you didn't get some wires or a drain hose caught under the cover ..... Did you remove the cover complete with the slave cly ? Or did you remove the hose for some reason ? There is no reason to bleed it if you didn't break the line loose...
I have seen guys pull the cly off the cover and have the puck come out to far and get stuck cockeyed in the very end of the bore ...
Let us know what you find out ...
michaelball31
posted April 16, 2008 02:39 AM
Hey smokin, Yeah I used a pak from schnitz, which Ive used before.I will repull the cylinder to make sure I didnt catch on something.Will let ya know later.Thanks
kawasaki_rick
posted April 16, 2008 04:42 AM
Did you put new springs in it? if so look at those. i got a set from schnitz and they coil binded up. cant find the part no. but they were race style. leave the cover off to see what clutch is doing. hope that helps.
0.21480393409729 seconds processing time
