BIKELAND > FORUMS > ZX-14.com > Thread: How low can I go? NEW TOPIC NEW POLL POST REPLY
Busa Tamer
posted April 14, 2008 07:56 AM
How low can I go?
Front lowered 1in, 3 hole lowering links,swingarm extension set at 6in.over ,stock undertail.I have it in second hole-1 1/2.in. Can I go to 3rd hole- 3in.without hitting?
BobC
posted April 14, 2008 08:29 AM
If it's any help, my bike has Muzzy 3 hole links which give standard height, 3 inches and 6 inches lower. The wheelbase is stock and I drop it 3 inches without any problems.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
nicks14
posted April 14, 2008 09:17 AM
u can go to the third hole but your fuel pump will hit the swingarm, i never did any damage to mine but i bought a mcintosh swingarm for a piece of mind, also look out for the shield and the bolt on your oil pan but i think u will be fine as long as you keep your front where it is!
hellraiser
ninja12
posted April 14, 2008 10:47 AM
Take a grinder to that bolt and shield .
KAWABUNGA
Cogswell Cogs Installed
posted April 14, 2008 12:07 PM
It would probably be a good idea to get with Muzzy's, they have shock travel limiters to prevent bad things from happening. Also it wouldn't be a bad idea to cut a 1/16" thick piece of aluminum plate the size of the ECM to place under it in the event of rub through if tire contacts the undertail.
0.22397899627686 seconds processing time
