BIKELAND > FORUMS > ZX-14.com > Thread: i am new to this forum, zx 14 mods NEW TOPIC NEW POLL POST REPLY
Smooth_G
posted April 11, 2008 10:00 PM
whats happening guys,,,give me your input,,,i got a 2008 zx14, i am putting brocks ceramic coated street meg, p/c 3, 16 T primary to start with,,,speedohealer,,,remove flies,,,,,,adding a second fan,,,,i want wire in 2 toggle switches,,,,,1 directly from the battery to the fans,,, and 1 from the battery to the water heat sensor to the fans,,,,,,so that way the fans will run until the heat goes down below 203 degree,,,and turn off,,,,,guys what about the spark being retarded in the first 4 gears,,,,do u guys use a ignition modulator
smokinzx14
posted April 12, 2008 06:42 AM
do u guys use a ignition modulator ?
That would be a NO ...I run 8s without one ....
I don't know why you would need a second fan either ..
Smooth_G
posted April 12, 2008 08:52 AM
hi smokin,,,,,,thanx for the answer,,,,i have been reading your stuff,,,,,u seem very knowledgeable about these machines,,,,,,,,,it gets 120 degrees here,,,,i know once i get all smog shit off it will cool down,,,,,,i got pipes for my FJR 1300 it really helped,,,,,ok,,,the bike isnt moving,,, so it heats up,,,,the fan comes on,,,,then the bike cools and the fan turns off,,,then the bike heats up again the fans goes on and off,,,,this bike the fan never turns off while standing still,,,,this tells me there is not enough air flow going through it,,,,,what do u think about,,,,,evans cooling systems,,,,anti freze,,,,
NinjaNick
'08 ZX14 (Blue)
posted April 12, 2008 08:55 AM
You sure have a lot of toys.
mini-bike, go cart, cushman 1962 Honda 50, 1964 Honda 150 1966 Honda 305, 1970 CZ 400 1957 Triumph Tiger 650 T-110 1972 Triumph 750 Bonneville 1972 BMW R75/5 1974 BMW R90s 1982 KZ 1000 2005 Ducati Monster 1000s 2006 FJR 1300 2008 zx14
KawaBonzai
Leader of the Back.
posted April 12, 2008 10:39 AM
I'm reporting you for comma abuse! hehe j/k
Welcome to the ZX-14 crowd.
... Bonzai
2009 ZX-14 Candy Lime Green
Smooth_G
posted April 12, 2008 02:03 PM
THANX,,,,,,,,,,,,,,BONZAI,,,,,,,,,,,,,,,,,,,,,,, I RECOGNIZE,,,,,,,NICK THATS FROM THE AGE OF 8 TILL PRESENT DAY,,,,,,AGE 55,,,,,ALL I HAVE LEFT IS THE 08ZX14,,,,,N,,,,,2006 FJR 1300,,,,,JUST GOT BACK FROM A RIDE THROUGH THE CANYONS,,,,,TOOK THE FJR,,,,,,ZX14 BACK TIRE IS SHOT FROM BURN OUT,,,,
FasterThanStink
posted April 12, 2008 04:41 PM
Turn the caps lock off before Fish eats you alive. :P
That's what gets you.
0.26708698272705 seconds processing time
