BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy air shifter NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted April 11, 2008 04:56 PM
Muzzy air shifter
Will any wires have to be spliced at all or is every connection a plug-in? Second, it does not have a compressor it appears and I am wanting to know what kind of air pressure is required in the tank to operate correctly.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
smokinzx14
posted April 11, 2008 07:42 PM
If you have the Muzzy c02 air shifter you will have to fill the bottle with co2 or N20 ...I use n20 because it easier to find some one to fill the bottle ... ...Muzzy c02 air shifter is plug and play ...no wires to cut ....You do have to unplug some factory wires and insert the Muzzy wires in the kit ...
smokin..
spyder636
posted April 12, 2008 05:55 AM
I just recently installed the muzzy kit and it was fairly easy. It came with good instructions and works great. I would recommend it. Smokin did you have to adjust your delay or kill time at all after installation.
smokinzx14
posted April 12, 2008 06:38 AM
No i did not have to adjust the kill time .... It worked great just as it came from Muzzys ...
kawasakijockey
posted April 13, 2008 07:42 AM
Thanks Smokin. The product description leaves the important info out. So the bottle in this kit would have very high pressure nitrous or co2 and not compressed air, right? If its high pressure there is a regulator after the bottle? I do appreciate your patience in explaining all of this to me. I would call them about it but it is the weeekend.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted April 13, 2008 10:06 AM
yes, its got a regulator...
brent davis
posted April 13, 2008 10:08 AM
I'm with Smokin', I installed the kit and never touched the digi-kill time. It is the same as it came from Muzzy and works like a champ. I use a on-board pump to supply the air to my tank though, no filling bottles for me. Just turn the pump on and fill the tank.
Black '06 ZX-14
0.40553402900696 seconds processing time
