BIKELAND > FORUMS > ZX-14.com > Thread: Running cooler w/ aftermarket exhaust. NEW TOPIC NEW POLL POST REPLY
KawaBonzai
Leader of the Back.
posted April 07, 2008 09:24 AM
Hi there,
Just trying to clarify some things I heard from folks.
Does running an aftermarket full exhaust like Brocks or Muzzys help the bike run cooler / less heat buildup?
It's going to be 110+ this summer in Southern Az. I'm trying to shave degree's off.
... Bonzai
2009 ZX-14 Candy Lime Green
posted April 07, 2008 10:08 AM
yes much cooler, the cat converters will be eliminated.
lietoome
posted April 07, 2008 10:20 AM
Huge difference in temperature with my Brocks exhaust. Gets pretty damn hot in El Paso too---no issues after ditching my stock exhaust.
johnnyrocketzx14
posted April 07, 2008 10:23 AM
same result here in the middle of Texas / with muzzy much cooler/ no issues
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
  Ignore this member    Click here to visit JohnnyRocketZX14's homepage.
posted April 07, 2008 10:52 AM
dump the junk...
put a pipe on it, runs much cooler, and good 4-1 much stronger.
15 RWHP at peak ~9300 rpm, and +30 RWHP at 11,000 rpm!
butterthegreat
posted April 07, 2008 11:10 AM
Does a slip on remove the cats or is that only on a full system?
zx14mike
posted April 07, 2008 11:19 AM
The 14 runs MUCH cooler with an aftermarket exhaust, and like dubious said topend over rev is much better as well.
posted April 07, 2008 12:19 PM
slipos will remove as the cats are in the mufflers. but it will still leave you with the heavy, hot, JUNK cast iron factory header
BobC
posted April 07, 2008 12:56 PM        Edited By: BobC on 7 Apr 2008 13:59
My experience too, much cooler without the standard system. The fan does still cut in sometimes but not every time you're in traffic.
I can put my hand on my bikes Titanium silencer without losing skin. When I first bought my 14 in 2006 I touched the standard system with a bare leg 5 minutes after turning the engine off and I've still got the scar. 'Nuff said.
On the 2008 bike there is a third Cat in the collector as well as the two in the mufflers.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
14black
posted April 07, 2008 02:04 PM        Edited By: 14black on 7 Apr 2008 15:07
My stock pipes burned the hell out of me a few times and melted some shoes, too. My c/f cans can be touched right after shutdown will no ill effects! You may also want to look into ceramic coating for the headers...
Raptor14
posted April 07, 2008 02:28 PM
I have Brock's Gen III StreetSmart. Prior to having the headers and mid-pipe ceramic coated it ran cooler than with the stock pipes, but, for me, the difference wasn't all that much. It still ran on the 4th bar when in slow traffic or sitting at a stop light. Ceramic coating really helped. Heat radiation from the headers into the radiator during slow going was significantly reduced. You can order ceramic coated headers and mid-pipe from Brock and maybe from aftermarkert suppliers as well. If you can't pre-order you can always have them coated like I did. The coaters are pretty busy however. I had mine done over the winter. If you have them coated by someone other than the supplier you'll need to mask the parts which fit together or have them expanded slightly. Otherwise the fit may be too tight and you'll have a hard time installing. I know Brock's coater accounts for this.
posted April 07, 2008 07:21 PM
the aftermarket pipe will definitely reduce the heat you will feel as a rider, and it does lower engine temp some
0.24172687530518 seconds processing time
