BIKELAND > FORUMS > ZX-14.com > Thread: clearance issues brocks SMEG NEW TOPIC NEW POLL POST REPLY
wikidzx-14
posted April 02, 2008 05:16 PM
I just purchased and installed my Brocks SMEG and am having an issue with clearance between the mid pipe and the oil pan. Where would be the best place to adjust that? And what would the propper clearance be 1/4". Any info would be appreciated.
Thanks in advance.
Black 07 ZX-14, Stretched to 64", Lowered 1 1/2", Brocks SMEG, Flies removed, PCIII, Brocks Map, 200/50/17 rear tire, 16/43 gears, Heli Risers, Tobin Seat, Fender Elim,
posted April 02, 2008 08:02 PM
before you tighten everything you can move the pipe around to the correct position, looosen it up move it and tighten
smokinzx14
posted April 02, 2008 08:06 PM
If you can't get it worked out call Brock .. Service is job one with Brock....
mark524
posted April 02, 2008 09:49 PM
it is normal to be very little clearance. as long as they are not touching you'll be fine. this is what brock told me
sideways
posted April 03, 2008 02:24 PM
make sure you have at least a finger clearence between filter and header.
Joe
2006 Blue ZX-14
wikidzx-14
posted April 03, 2008 03:37 PM
Thanks guys I got it figured out, all I have to do now is put the ultra copper on the mid pipe and tail pipe sections and I am done.
KawaBonzai
Leader of the Back.
posted April 03, 2008 03:46 PM
Grats ! Are you upgrading from the stock pipe?
Let us know your impressions when you get it all done.
and of course ... Pics !
... Bonzai
2009 ZX-14 Candy Lime Green
wikidzx-14
posted April 03, 2008 05:27 PM
Yes upgrading from the stock ppes and headers, to the SMEG, so far I love the looks, and it should sound awesome. All I have left to do is put the Roaring Toyz swingarm extensions and lowering links on, and I will be done the upgrades for this year. I will post pics and video as well if I am able.
0.2574028968811 seconds processing time
