BIKELAND > FORUMS > ZX-14.com > Thread: front sprocket removal NEW TOPIC NEW POLL POST REPLY
wikidzx-14
posted March 25, 2008 05:04 PM
I searched the forums for instructions to remove the front sprocket. What is the best course of action? What size of socket? Or is there a special tool?
Thanks for your help.
Black 07 ZX-14, Stretched to 64", Lowered 1 1/2", Brocks SMEG, Flies removed, PCIII, Brocks Map, 200/50/17 rear tire, 16/43 gears, Heli Risers, Tobin Seat, Fender Elim,
hardcoremass
Powerhouse
posted March 25, 2008 05:16 PM
There is a post on this page (help front cover) that may have the info you are looking for. You could also use the search function to locate other posts regarding removal of sprocket.
Hopefully this helps.
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
NinjaNick
'08 ZX14 (Blue)
posted March 25, 2008 05:17 PM
http://www.bikeland.org/board/viewthread.php?FID=27&TID=37959&set_time=
Wheelie
Old Man
posted March 25, 2008 05:18 PM        Edited By: Wheelie on 25 Mar 2008 18:30
1 1/16th socket
wee
hardcoremass
Powerhouse
posted March 25, 2008 05:23 PM
Thanks Nick, have yet to figure all that fancy shit out.
wikidzx-14
posted March 25, 2008 05:35 PM
so 1 1/16 socket, and what a breaker bar? I assume an impact would be too much for it.
thanks
Tool man
posted March 25, 2008 05:38 PM
thanks
Nope...Impact is the way to go. Make sure your socket is a 6 point impact socket. A 12 point may round over the nut. It's a tight sucker
The banks are failing..
The banks are failing...
Invest in Ammo
wikidzx-14
posted March 25, 2008 05:40 PM
thanks very muchfor the help
NinjaNick
'08 ZX14 (Blue)
posted March 25, 2008 05:43 PM        Edited By: NinjaNick on 25 Mar 2008 18:43
Make sure you don't have it in gear and going against it!
Wheelie
Old Man
posted March 25, 2008 06:03 PM
thanks
sorry, forgot to mention the 6 point socket!!
wee
pontiacpassion
posted October 21, 2010 05:08 PM
ok, obviously i'm missing something if you use a breaker bar r how do you get the front sprocket from not spinning when you turn? An it not reverse threads is it???
posted October 21, 2010 05:17 PM
You can get someone to hold the brake, or stick a 2x4 through the rim and let it rest on the swingarm. It's a 27mm socket.
Better get a long cheater bar as some of them are more than tight.
pontiacpassion
posted October 21, 2010 05:21 PM
ahhh, i need chain intact then! dammit!!!
posted October 22, 2010 01:21 AM
Yes go ahead and put your new chain on
INTIMIDA2OR
RED rider!
posted October 22, 2010 01:33 PM
Yes put the chain on then remove the sprocket and install the new one.
'06 Passion Red ZX-14
*Lee*
pontiacpassion
posted October 22, 2010 07:15 PM
Pain in the arse..but problem is solved~! Thanx
posted October 23, 2010 04:08 AM
Yes it is a pain in the ass.
LAB3
posted October 23, 2010 05:09 PM
Make sure you push back "ALL" the lock tabs that hold the sprocket nut on. There are 2 hex nuts you can use a 6 point socket on, the smaller one is a 27 MM and the larger one
that is flush againt the sprocket is a 1 1/16 or 35 MM but the depth on it is not as deep as the 27 MM. You will see when you are looking at it.
GREYHOUNDMOSES
posted October 24, 2010 01:34 AM
This is covered well in page 6 of Shanes build thread with good photos.
http://www.bikeland.org/board/viewthread.php?FID=27&TID=40269&pagenumber=6
a six sided DEEP socket 27mm is the correct size (this is a metric bike!)
1 1/16 is 26.98mm and will do fine but is NOT 35mm!
LAB3
posted October 24, 2010 05:30 AM        Edited By: LAB3 on 24 Oct 2010 14:13
I have a sprocket nut in front of me and Digital Caliper that goes metric and standard. The larger nut is a ruff casting and measures several different values from 34.89 to 34.77. My Bad the 1 1/16 is the small nut. This nut measures from 27.17 to27.03 on this one. Both hex nuts are a ruff casting and they will differ a bit. You are correct about the 26.98 being
a 1 1/16 . And thanks for the info. I think we all know where a 14 is made. :-)
0.27183389663696 seconds processing time
