BIKELAND > FORUMS > ZX-14.com > Thread: Mod chip instead of removing secondary flys NEW TOPIC NEW POLL POST REPLY
camperjohn64
posted March 25, 2008 01:31 PM
I met a guy today who also had a zx-14, and he said he had a mod chip to put trick the bike into thinking it was in 6'th gear just like the TRE does, but it does NOT always show 6'th gear in the computer panel. He said this was a better alternative than removing the secondary flys.
Does anyone know of this chip?
red1
posted March 25, 2008 01:58 PM        Edited By: red1 on 25 Mar 2008 14:59
CJ64,
Haven't heard of it, check with him and see what details you can find out.
Red12/Blue14
hardcoremass
Powerhouse
posted March 25, 2008 03:37 PM
What were his proposed benefits to running this TRE (or other similar unit) as opposed to simply removing secondaries and re-mapping. Just curious?
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
butterthegreat
posted March 25, 2008 04:00 PM
Removing the secondaries and remapping is much more bang for the buck than running a TRE.....not to mention...it just works better.
hardcoremass
Powerhouse
posted March 25, 2008 04:32 PM
My thoughts exactly!
davesxx01
posted March 25, 2008 04:56 PM
It's called a GI-pro atre. Same place that does the speedo healer.
Benefits over just removing flies? None, except you dont have to worry about stripping screws, you can return you bike to stock at the push of a button, you dont "need" a PC III.
Had one on my '07, worked great. Still ended up pulling the flys and replacing the exhaust, putting on a PC III.
For my '08 I'm leaving the flies alone, still putting on the pipe and PC III though.
'01 CBR1100XX, '06 ZX-14, '08 ZX-14SE Brocks Street Smart, Rick Meyer seat, Risers, Throttlemeister, a few other goodies.
'09 MV Agusta Brutale 1078RR. Arrow full exhaust, Race ECU.
'12 ZX-14R Guhl flashed.
hardcoremass
Powerhouse
posted March 25, 2008 05:00 PM
Does this unit offer the same results as the speedo healer, bypassing the factory limiter?
FASTESTbusaAROUND
I eat Fish...
posted March 25, 2008 07:40 PM
GI-Pro does lose the gear indicator guys....only thing, is that it has an external gear indicator (Ughhhhhh)
...zero benefit and still under-performs against the fly's out mod, not to mention the lean condition that it doesn't address. You do need a PCIII with it, or you stand the chance of burning your pistons.
Lot of $$$ to waste on that...
FYYFF!!!
davesxx01
posted March 26, 2008 06:28 PM
Speedo healer and ATRE are 2 different products.
The gear indicator on the GI Pro I thought was much better than the factory one, larger, brighter, faster reacting and accurate.
It does work better with a PC III though, as would any bike without flies.
camperjohn64
posted March 27, 2008 10:38 AM
His chip did what the TRE does, only it showed the correct gear in the computer. It was not an external gear indicator. It did nothing more than what the TRE does and was not a substitute for removing the flys.
I didn't get his name, since he gave me some keywords to look for on Google, but when I searched for zx-14 override chip on google I couldn't find it. I guess I was too confident that I would find it.
I don't think he was talking crap either. So I am still looking for the chip rather than the TRE. If I can't find it, I will just remove the flys and get a power commander.
Wheelie
Old Man
posted March 27, 2008 10:55 AM
where did he say the "chip" would install?
wee
camperjohn64
posted March 27, 2008 12:42 PM
Dunno, I should have been more attentive. I was just thinking "Oh, I will search online and it will come up first thing".
0.40567684173584 seconds processing time
