BIKELAND > FORUMS > ZX-14.com > Thread: Rubbibg undertail Bad NEW TOPIC NEW POLL POST REPLY
johnnyrocketzx14
posted March 24, 2008 05:26 PM
ok i know im not the only one who is having this problem.
64"s ,last hole on links, 212lbs with gear,
finally get my suspension where i hook and like the damping and rebound and i look under the tail to find this HUGE hole!! What can i do? i have seen the tiger tail but i am sure i will rub it too, just maybe not a hole in it. i think its only doing it when i launch but not sure. i do seem to be short a few MPH at the top end. Is there a fix?
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
  Ignore this member    Click here to visit JohnnyRocketZX14's homepage.
Wheelie
Old Man
posted March 24, 2008 05:27 PM
lol,btdt. get the tiger tail and adjustable lowering links.
wee
johnnyrocketzx14
posted March 24, 2008 05:33 PM
would the middle hole maybe be ok? i really like it low, will raising hurt my launch?
07 ZX14
Wheelie
Old Man
posted March 24, 2008 05:36 PM
middle hole will work, but you still have a huge hole in the undertail.
wee
johnnyrocketzx14
posted March 24, 2008 06:08 PM
well not that i am looking to cause any more damage but there is only 1 concern > ET
if the question came up " what would you rather have, a slower ET or a hole in the undertail ?"
i'd take the hole lol
but the wire harness that is about to be trashed is unacceptable!!!
i figured i would buy the tigertail
thanks wheelie
now if it slows my 60' i am going to have to blame you
jk
07 ZX14
zx14bert
posted March 24, 2008 06:35 PM
Muzzys makes a spacer that goes on the shock that stops it from going down so low,there is one for middle hole and one for third hole.
posted March 24, 2008 07:21 PM
lol...
if you let it keep burning, it will burn up your ecm too...
mark524
posted March 24, 2008 07:42 PM
get a straight link
Silver08
posted March 24, 2008 07:43 PM
straight link and tiger tail really helped on mine @ 65"
08 ZX14
ninja12
posted March 25, 2008 12:45 PM
What bars are you guys running with the straight links?
Silver08
posted March 25, 2008 05:44 PM
Adams adj links
08 ZX14
johnnyrocketzx14
posted March 26, 2008 12:47 PM
Can you run the Straight link if you have the 3 hole lowering links? or must you have the Adams Adj links??
07 ZX14
spyder636
posted March 27, 2008 08:28 PM
When you guys talk about the tiger tail I have seen two model the entire section and one that basically replaces where the license plate bracket use to be. Will they both help or just the entire section
Wheelie
Old Man
posted March 27, 2008 09:19 PM
entire section.
wee
johnnyrocketzx14
posted March 28, 2008 08:12 AM
ok so i moved my links to the middle hole, bike is lots higher ( seems more than a inch but whatever)
still have the question bout if i need the adams adj links to go with the straight link? and what does the straight link really do? how does that set up differ from the 3 hole links? is it more than just a height thing?
07 ZX14
posted March 28, 2008 09:39 AM
The adams straight rocker arm ( straight link) changes the leverage ratio the arm has overe the shock, stiffening the suspension, and reduces suspension squat under acceleration, and over bumps.
Not sure if the 3 hole links will work or not, I have then short threaded ones.
The long tiger undertail will help clearnace somewhat, but not directly under the tailight, so it depends where the tire is adjusted to, and if you have an arm on it or not.
At least its made up of aluminum, and won't allow you to burn up any more parts.
johnnyrocketzx14
posted March 28, 2008 04:11 PM
so this is the tiger tail you are talking bout right? do they make one without the plate bracket? or do you just have to cut it off?
http://secure.mycart.net/catalogs/catalog.asp?prodid=4938045&showprevnext=1
07 ZX14
Wheelie
Old Man
posted March 28, 2008 04:18 PM
thats it.
wee
posted March 28, 2008 06:53 PM
I cut mine off, but MR POLICEMAN didn't like that much...
0.21849203109741 seconds processing time
