BIKELAND > FORUMS > ZX-14.com > Thread: Power Commander Settings NEW TOPIC NEW POLL POST REPLY
meridian
posted March 19, 2008 12:25 PM
Any advice on Power Commander settings? I have a PC3 with Muzzy Slip Ons and am having a problem with hesitation at about 3000 rpm and light throttle. If the bike feels hesitant would this indicate a lean or rich mixture? Any help is appreciated!
06 black, muzzy's, pc3, screen, hugger, heel guards, grips, frame plugs, heli risers
77 RD400, smoking is good for you
80 Z1R, zx14 of 1980
86 GSXR 1100, first of the superbikes
79 kz650sr, just like back in the day
79 CBX, size matters
billeason
posted March 19, 2008 01:18 PM
More than likely lean,do you have the secondarys out? Also did you install muzzy's map? Give us a little more info on your set up. I'm sure we can help!! Bill...
bill eason
meridian
posted March 20, 2008 06:46 AM
Hey, thanks for the reply! I installed the map for Muzzy slip ons with stock air filter and motor, which is what I have. I have not touched the secondarys (still stock set up). The motor hesitates so much at almost exactly 3000rpm that you have to increase throttle to get it over the hump and then it comes on as normal at about 3300 rpm. Problem is as normal is a major surge until you adjust back on the throttle to compensate. Thanks again for your help!
meridian
posted March 20, 2008 06:47 AM
BobC
posted March 20, 2008 07:13 AM        Edited By: BobC on 20 Mar 2008 08:14
It could be that your set-up with the slip-ons is making the normal flat spot at 3000rpm seem worse. It won't take full throttle at that engine speed anyway.
Best solution is to get those secondary butterflys out, you'll be amazed at the difference 15 minutes with a screwdriver can make. It's the best no-cost modification ever.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
meridian
posted March 20, 2008 11:32 AM
Any suggestions on where to find a "how to" on the butterfly removal? Thanks also for the info...it is appreciated!
hardcoremass
Powerhouse
posted March 20, 2008 03:17 PM
You can use the search feature to locate posts regarding secondary removal. If you have any questions just PM me and I will help in any way I can.
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
meridian
posted March 20, 2008 07:02 PM
Many thanks! I'll keep you posted!
JamesE
posted March 21, 2008 07:21 AM
Also go to www.powercommander.com for choices on maps. Just type in bike info and they'll pull up a lagre selection of various maps for you to choose from. Pretty damn cool!
07 Plasma Blue ZX 14 Flies out Tsukigi slip-ons, PCIII, -2" rear
-1" frt, Heli's, Scorpio SR500i equipped
meridian
posted March 21, 2008 09:55 AM
Thanks James! Already loaded the proper map but still have the problem. It's a bit of a drag as the main reason I went for the Muzzy slip ons was because power commander had a map for exactly that set up. Also, I thought that Muzzy had a long term relationship with Kawasaki so it should work perfect right out of the box! I think a dyno is in order but it's hard to find in Vancouver, Canada!
fury
posted March 21, 2008 04:25 PM
not that hard... Open the yellow pages. Find a performance shop.
There are a couple. Or goto Vegas... I know of a few.
meridian
posted March 21, 2008 07:50 PM
i'm going to Vegas next week, but unfortunately without the bike. Any good accessory shops you could recommend?
reckless
posted March 21, 2008 08:49 PM
If you don't mind travelling to the Langley area for a Dyno check out Murray at Newman Suspension. Just had my 14 on the dyno there to get an idea of HP before I start changing things.
meridian
posted March 21, 2008 09:01 PM
Hey, a local! I will call him Tuesday for sure! Thanks for the info!
meridian
posted March 21, 2008 09:04 PM
I got a resonse from Power Commander tech who suggested adding 3 bars om both the low and mid range adjustments. I made the change tonight and will try it out tomorrow morning.
joel787
posted April 11, 2011 09:52 AM
Anyone has a no flies map? Help apreciated
0.24314117431641 seconds processing time
