BIKELAND > FORUMS > ZX-14.com > Thread: Four to Two Performance Exhaust System NEW TOPIC NEW POLL POST REPLY
KikonZX14
Novice
posted March 17, 2008 10:44 AM
Hi guys,
Any of you knows if there are any four to two performance exhaust system that might use to replace the stock ones?, I do like the two exhaust configuration and would like to keep it.
The ones I've seen here so far are all four to one (Brock's, Muzzy's, etc.).
Advising / Comments / Suggestions / do's & don't are welcome.
Thanks & Regards,
David
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
Sticks_n_Stones
posted March 17, 2008 12:19 PM        Edited By: Sticks_n_Stones on 17 Mar 2008 13:20
Strict performance, the 4 into 1 is the best. Mostly because of weight, and weight placement on the bike. (the lower and closest to center of bike the better). I use slip-on Two Brothers, which is popular for slip-ons.
I dont know if they make full exhausts, but I would put $ on it.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
KikonZX14
Novice
posted March 17, 2008 12:34 PM
Thanks Sticks_n_Stones, those slip-ons goes four to two or just four to one?
Which is the difference between slip-ons and full exhaust systems?
Best Regards,
David
qwick
posted March 17, 2008 12:54 PM
David, I'm not familiar with a performance aftermarket dual exhaust system either. But I do know who you can call to see if he'll build you one. His name is Jon Cornell (Drag Racer) he lives in Ohio and is the owner of UFOcycles.com & Tailwindz.net. I have already spoken with him on building a 4-2-2 system for the ZX14, but there has not been enough interest in the idea to start a production line. Jon has been building a killer complete dual system for the Vmax for many years, so he knows what he's doing when it comes to the dual systems. Jon also currently has a 4-1 system for the ZX14, so maybe he can make a few mods to his existing header and Voila, a 4-1-2 system may be possible for you. I'm not sure of the benefits that this type of system would have, but surely it would have to be a step up from the "typical" dual slip-on systems that rely on the factory head pipe. Just tell him to add two of my upgraded megaphone "Qwick Megs" to complete your system (no joke). Give him a call (440) 582-2525 just leave him a message if you get the voice mail, his dyno runs all the time, so he may not hear the phone ring. Or pm me if I can help you at all.
Kevin
Sticks_n_Stones
posted March 17, 2008 01:16 PM
Hooking a friend up eh? its cool qwick, you're one of the guys around here that wouldnt steer anyone wrong.
Yes Kikon, mine is a four into two. Slipons hook up just past the center of the header right behind the oil pan. Look on yours you will see where the factory ones mount up. Basically just past where you can see my exhaust pipe heading under the bike.
The stock header is apparently confining, with a aftermarket header you can pick up between 5-8 HP more supposedly. And the drawbacks to a dual exhaust are: weight, clearance of chain, weight, and simpler routing. And weight. Eventhough it only weights another two or 3 pounds, alot of guys here think that is a big difference. I could give a shit myself lol. I just like the duals look. Just not the huge stock duals!
Oh yeah, here's Brocks own words he emailed me about slip-ons versus full exhaust. ( I havent downloaded the dyno graphs yet)
"I just sent you the run view information.
After you download the program- you can view the attached run files of a stock ZX-14 exhaust vs. our slip-ons. FYI- these make the best power of any slip-ons we have ever made/ tested.
Please note- The files attached are from a different dyno than mine on a bike which has had nothing done to help power- thick oil etc.
The numbers are lower than we see (some Dyno's are as much as 10 HP different from the next) BUT- you can clearly see the improvements.
Also note- they tested backwards. The bike arrived with the dual slip-ons and was converted back to stock to measure the difference our of my curiosity at a alter date.
Let me know if you have any other questions.
Brock"
------------------- AND --------------------
"I have them....just not packaged and easy to read.
I will send you information which shows our latest prototype dual outlet megaphones vs. our full system.
You will need to view the dyno graph using a program called run viewer.
FYI: the dual outlet megaphone slip-on system is almost the same price as our full system! That's why I feel it is a waste.
Brock"
I guess tomorrow I'll have to finish the article I started about it once I download all the data/ dyno runs. cant procrastinate it any longer.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Silver08
posted March 17, 2008 02:42 PM
More options for the 14 would be a good thing. Get him to build it
08 ZX14
kikonzx14
Novice
posted March 17, 2008 03:58 PM
Thanks S_n_S & Kevin, I appreciate waaaay much your help in this matter. Most likely I will do the transition to install a different exhaust system once I dominate the "stock" power and when I feel confident about my "sport bike driving skills".
I was wondering if any of you guys tried the stock exhaust when you removed the flies and installed PCIII (am I missing something?), what happened?, do you believe the stock "pipes" or cans can handle it?
Because I feel that the maximum power to be taken out of a ZX14 will be used mostly on the dragstrip and not on streets......Right or Wrong?
As far as here in Chile we don't have a proper fitted drag racing site, most of the speed I would like to get out of my "land missile" will be on highways. When I feel ready, I really would like to reach the top speed with stock limitation (186 mph....150 mph so far) and "break" or at least reach the 200 mph, once the necessary modifications are done.
Thanks again to all of you for your help and good advices.
Best Regards,
David
posted March 17, 2008 07:30 PM
get a 4 into one ya puss
KikonZX14
Novice
posted March 18, 2008 02:28 AM
Yeah I know Bigtd, I'm a wuss. But I suppose everyone should know their limits and extend them once they feel comfortable doing it. Better to be safe than sorry, ya'know.
BTW, I saw that Muzzy's have a 4-2-2 exhaust system for the Concours.....that one might work, hu?
Best Regards,
David
posted March 18, 2008 04:29 AM
David,
Unless you are chasing the looks of a 4-2, don't waste your time or money and get the performance oriented 4-1,
whether it be brocks, or ti force, they are both very close in power, and 10 HP more is not going to kill you, the stock bike could do that easilly!
The concourse likely has different mounts for the cans etc,
No need to reinvent the wheel.
spend your money wisely, and spend it once.... go for the gusto....
just have respect for the machine, and ride smart
lietoome
posted March 18, 2008 04:45 AM
If you like the look of the dual cans, get a pair of slip ons.
If you think it needs more, pull the flies and have it mapped.
Next step would be -1 on the front sprocket.
After you've done these steps in this order, then you'll know if you want a full system.
As you already know, the 14 had stupid speed and power. Just take your time, and get used to the bike----especially the flies mod, and the front sprocket.
Just take it easy and don't get in over your head, it happens much faster on this bike.
KikonZX14
Novice
posted March 18, 2008 05:21 AM
Thanks Lyle & lietoome, when the time comes.....will let you know what I finally did. I am trying to take it easy, specially moneywise since I've spent too much money and wifey is getting mad at me. In the upcoming year, it'll be one thing per month i.e: next month= leather Jacket + stands , following month= leather pants, etc., etc.
I like Lyle's sentence: go for the gusto......, that's the way it always should be.
Best Regards,
David
LeoVinceZX14
Thankfully...its paid for...
posted March 18, 2008 11:59 AM
Check out the new Muzzy's 4-2-2 system for a Concours 14..
KikonZX14:
Looks like you might want to give Muzzy a call and ask whether the Concours 14 4-2-2 system can be adapted to your 14. Good luck.
Ride safe....
'12 14R SE
PC V
Custom map
BMC filter
Leo Vince 4-2-1 w/ carbon can
Sato frame sliders
Supersprox 42T
Cox radiator guard
DID 530 X-ring chain.
Sticks_n_Stones
posted March 18, 2008 01:19 PM
If it helps, there is guys on here that have put the stock 14 exhausts onto there 14 Concourse's. Should be a two way street.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
kikonzx14
Novice
posted March 18, 2008 02:38 PM
Thanks Guys, I really appreciate your advising on this matter.
Hugz & Best Regards,
David
posted March 18, 2008 02:47 PM
we are all just having some fun, get out there and make some noise with that 14
Sticks_n_Stones
posted March 19, 2008 05:50 AM
Hey keep those hugs to yourself! And Dubious, too. I heard he plays for the other team...
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted March 19, 2008 06:19 AM        Edited By: dubious on 19 Mar 2008 07:20
Your plate still looks like it reads "pussy" LOL
and your only if your on the take.... so they say.
KikonZX14
Novice
posted March 19, 2008 06:28 AM
Ok, Ok, ............I will even though I just turned 40, I'm not looking for new "sensations"
Hugs....ooops did it again.....Britney?
KikonZX14
Novice
posted March 19, 2008 06:29 AM
LMFAO
KikonZX14
Novice
posted March 19, 2008 10:06 AM
Hey guys, I've found this while snooping around eBay.
Brand new pair of Scorpion carbon fiber exhaust canisters for the 06-07 Kawasaki ZX14R. (Satin titanium shown above on the bike). Straight from the old country, these nice, deep sounding Scorpion cans are one of the most underated exhausts around. They are very well made, with one of the longest lasting muffler packing out there. Also available in polished stainless, satin titanium and flame titanium. Includes all mid-pipes and all hardware neccessary for a great fit and installation. Please allow up to two weeks for delivery as not all systems are in stock at all times. Feel free to contact us for current availability. We carry the entire Scorpion line and 20 others. We are the exhaust kings!
Any of you know these ones?
Thanks in advance.
Best Regards,
David
Sticks_n_Stones
posted March 19, 2008 10:08 AM        Edited By: Sticks_n_Stones on 19 Mar 2008 11:10
Think you guys need to set your screen resolution a bit higher! Or go get some glasses ya blind old bats.
No, I've never actually heard the Scorpions. Carbon fiber you cant go wrong with though. How much?
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
KikonZX14
Novice
Here's a pic of the system installed on a ZX14
KikonZX14
Novice
posted March 19, 2008 10:09 AM
Group Hugz???
KikonZX14
Novice
posted March 19, 2008 10:13 AM
I've found more........WOW
Brand new pair of M4 "Retro Drag" GP-style dual black ceramic slip-on canisters for the 06-07 Kawasaki ZX14R. These have got to be the most radical slip-ons for the big ZX that has come along yet! Loud, short, black and affordable. Comes with two canisters, all required hardware and instructions. Easily installs onto the end of the stock system. They say:
"M4 Performance Exhaust introduces their Retro-Drag slip-ons for the monstrous Kawasaki ZX14. These dual ceramic black slip-ons give your ZX14 a new look and sound that will turn heads. This new product offers very noticeable horsepower increases that add to your already super-fast Kawasaki. The stock silencers have got to go since they are 20lbs. heavier than the M4 Retro-Drag slip-ons."
M4 makes some very nice high-performance systems. One not need look further than the starting grid of any AMA road race to see how many privateer teams use their pipes.
We carry the entire M4 line along with 20 others. We are the exhaust king!
Pics:
0.23790502548218 seconds processing time
