BIKELAND > FORUMS > ZX-14.com > Thread: brocks street gen3 with map? NEW TOPIC NEW POLL POST REPLY
lawnplus
posted March 15, 2008 03:08 AM
Just got my new zx14 (06 leftover x2) going to order brocks street smart gen3 ti, If i order it with pc3 does it come with track map installed? also how is the fit no mods to any plastic?
i just want something that fits nice.
thanx plus
lietoome
posted March 15, 2008 03:24 AM
fits exactly like the stock exhaust. Just let them know which map you want. You will have access to all the maps thru Brock's site. I Love my Gen3!
lawnplus
posted March 15, 2008 03:42 AM
thanx lietoome
hows the sound and performance compared to the short meg im looking for something not too ear piercing? also what map do u recomend, im going flies out mostly street w/ a bit of time at the drags.
posted March 15, 2008 05:26 AM
the performace is close, probably 3-4 HP and the sound is quite a bit quieter.
run the streetmap no flies for best drivability, and his no flies track map with your a/f removed.
If you have a laptop, changing maps takes like 1 minute!
Call Brock, he is very helpful and will make time, (especially) if you have visa in hand,
....he is afterall a busy guy and gets allot of BS calls I imagine...
lietoome
posted March 15, 2008 08:47 AM
I'm was running the map that I got from Brocks(street/no flies) for the Gen3. I dynoed shortly thereafter(173 hp, 106 tq @4000 ft.). Never dynoed the stock exhaust, so I cant tell you the # difference between the two. I use the SMEG conversion with the track map for racing. Just me, but I wouldn't run the SMEG on the street. The SMEG sound can be a bit too loud when I'm riding with my wife or on the way to work early in the morning, so I started using the Gen3 again. The sound of the Gen3 is....Perfect. Deep with a lot of balls, but not obnoxious. I also have the carbon fiber cannister which is absolutely flawless. You can't go wrong with the Gen3. If I had it all to do over again, I'd go with the exact same setup, but I'd also have it ceramic coated by Brock's--just for looks.
to answer your question of the performance between the two...I can't ellaborate. They both haul ass. Take a look at Brock's alienhead exhaust and a 'db plug' if you want a pipe for street and race.
Did I mention Brock's customer support & service? Its refreshing to be appreciated as a customer, great experience with Brock and his crew.
FWIW, the street map with no flies ran really rich down low for me--I'm also at a higher elevation though. The fella that tuned my bike started with the brock map and removed a bit of fuel down low. He didn't change the mid & top of my map because he couldn't improve Brocks map thru that part of the map.
posted March 15, 2008 09:07 AM
love my street meg, i've got a bmc filter and i run the track map or the the maxton map, living in largo fla. great fit and support.
posted March 15, 2008 09:51 AM        Edited By: stevewfl on 15 Mar 2008 10:52
"If i order it with pc3 does it come with track map installed?"
to answer your question, the PCIII I ordered form brocks came with a gen3 map flies in preloaded. it also came with a password to load any of the maps I want to my computer, and was very simple to do.
call brock's with questions, they have the best customer support you will find anywhere.
for contact info click here: brockracing.com
0.21616196632385 seconds processing time
