BIKELAND > FORUMS > ZX-14.com > Thread: Elevation robs Horsepower BIG TIME! NEW TOPIC NEW POLL POST REPLY
200hp_zx14
posted March 07, 2008 08:52 AM
Here's the story, I live in Southern AZ and the elevation here is pretty high (4500ft avg but ranges from 4200 on up to around 5300 in some places). I put my muzzy full Ti/Ti pipe as soon as the pipe got released. I also put on a PC3 as soon as those got released. I deployed to Iraq, blah, blah, blah and now that I've been back for a few months I've added a BMC filter. I finally had a chace to get my bike to a dyno shop in Tucson. Its was a little mom and pop shop that specializes in ATVs (great service at Racers Edge) but they said they would help me out for cheap. It wouldn't be worth it to drive to Phoenix to get to a proper shop only to gain 1/2hp and spend about $300. One hour of my time, $60 and I gained almost 5hp and 3lb/ft. I figured with the elevation I would lose about 10% power and tourque. I guessed I would come in around 160hp and leave around 165hp. I was damn near dead on. Here are the numbers, I'll post a scan of the print out later today.
Before:
159hp
95lb/ft
After:
164hp @ 9888
98lb/ft @ 7750
Mods: Muzzy full Ti/Ti, BMC filter, PC3
Factoring in the elevation (2750ft) at the dyno site I figure I am putting about 180/185hp and 106/108lb/ft to the wheel at sea level.
About $1800 in mods and I am putting out stock power!!! I can't wait to change duty stations again.
What do you guys think?
207HP* '06 Candy Blue ZX-14
Some mods done
Best run - 10.19@137.40mph
NinjaNick
'08 ZX14 (Blue)
posted March 07, 2008 08:59 AM        Edited By: NinjaNick on 7 Mar 2008 09:00
That is WILD! Huge HP loss!
qwick
posted March 07, 2008 09:10 AM
200, Thanks for your Service to this Country!!! Very glad to know that you made it back home safe.
200hp_zx14
posted March 07, 2008 09:51 AM
Thanks qwick
Some mods done
matt sterbator
Hiding in the bushes
posted March 07, 2008 10:06 AM
You in Tucson or Sierra Vista/Huachuca ?
200hp_zx14
posted March 07, 2008 10:37 AM
Here's the dnyo sheet.
Some mods done
200hp_zx14
posted March 07, 2008 10:38 AM
I'm in Sierra Vista
Some mods done
billeason
posted March 07, 2008 12:37 PM
It should be more like 177 hp at sea level all things being eqaul, Same dyno,etc.. I struggle with this on a guys pikes peak qaud. Until this season he's been running a highly modified 660 raptor thats carborated,and pike offers drastic elevation changes. Using this formula you should see about 10-12 hp diviation.... Bill...
bill eason
200hp_zx14
posted March 07, 2008 02:28 PM
What formula do you use to factor to sea level? I was just guessing 10% loss due to the elevation. I could be wrong because I didn't get a chance to look up any correction factors online.
I did look up the 1/4 mile correction factors from the NHRA website. The track here in Tucson (3075ft) I've run a best of 10.55@136mph. Corrected thats something like 10.1@141mph. Thats not bad for stock wheel base, my mods and me weighing about 245lbs suited.
Some mods done
Sticks_n_Stones
posted March 07, 2008 02:41 PM
Dont worry about the HP loss and lower elapsed times 200, all that matters is the guy next to you has the same problems, and you just smoked him.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
billeason
posted March 07, 2008 04:53 PM
The easiest way is to go to brock's site and i think its the diaries he talks about the correction factor! I use the Aarc, sniffer,Its exspensive but worth every penny and it doesn't use a preset % it takes all factors such as humidity,wind temp,temp and pressure. If you have more than one bike for racing or run at alot of differant tracks invest in one. If not most tracks have posted conditions you can correct to.. Bill....
bill eason
serius blk
posted March 07, 2008 08:36 PM
only problem with sea level is most of the time you have alot of humidity.
flyboy
posted March 07, 2008 10:15 PM
200 hp. -- Welcome home. You're experiencing the effects of density altitude which one becomes quite familliar with once they obtain a pilot's license. As a non-turbo airplane climbs in altitude he loses power and as the temperature gets higher the effects are even worst for an airplane engine. Pilot are taught never to take off at a high altitude runway where the temperature is hot-- like in the middle of a summer day. You might not make it off the ground. You learn to take off in the early morning or early evening.
There is no need to modify the 14 engine for higher altitudes. It does it automatically. If you want max power take out the air filter and change the gearing.
At Bonneville I ran195.1 mph, stock engine, at a density altitude of 6,700 ft. with a power lost of 12-15%. I always wonder what that speed would be at sea level. And thanks for serving our country.
"The World's Fastest Indian"
One fast red ZX-14,
200hp_zx14
posted March 08, 2008 09:46 PM
Thanks everyone for the well wishes.
I know my bike is down on HP just like every other bike out here. I made this post not really to complain but just to point out some facts now that I actually have a dyno to prove what I already knew. I know the bike is still strong as hell cause I ran it up to an indicated 191mph twice now and it hit the limiter but still had plenty left in it. Maybe was at 10/10.5k rpm when I did it. I might have been doing 175mph or so actual ground speed. I have no doubts that the bike is strong, just kinda upset to prove what I already knew.
Some mods done
kikonzx14
Novice
posted March 08, 2008 09:59 PM
If not wrong, for each 100 mt above 1.000 mt, you loose 1% of power. Metric here in Chile, so you better use a conversor for ft.
Welcome back.
BRegards,
David
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
fury
posted March 09, 2008 05:01 AM
Come to Ontario Canada and make more power!
0.23038506507874 seconds processing time
