BIKELAND > FORUMS > ZX-14.com > Thread: Where to mount a shift light? NEW TOPIC NEW POLL POST REPLY
mark524
posted March 04, 2008 05:07 AM
If you have an aftermarket shift light, where did you mount it? I have the MSD 89631. It's one piece, so that's all I have to mount, but it's tight. I tried to put the mount behind the gauges so the light would be between the gauges and the windshield, but there isn't enough room. Post pics if you can. Thanks.
jarhead
posted March 04, 2008 06:16 AM
I had the Dyna and mounted it off of the top right windscreen bolt and it worked pretty well there. Over the winter I switched over to the Raptor which is similar to what you have. I velcroed it to the windsreen, I am not sure how well it will work but I figured I would give it a try. I ran about a 6 inch strip on the underside at the top so it would give me adjustability and then put the other side of the velcro on the mount for the light.
posted March 04, 2008 07:48 AM
I bolted mine to the back of the guages, using the top center bolt for guage housing, but I am running puig dbl bbl.
Wouldn't be able to do it with stock screen.
I can't post pics from work computer
mark524
posted March 04, 2008 08:00 AM
that's exactly what I tried, there just wasn't enough space with stock windshield. I'm thinking about putting some washers behind the cluster on that same bolt to angle it down a little, which would give me a little more space. I want the shift light to be in the center.
0.39099907875061 seconds processing time
