BIKELAND > FORUMS > ZX-14.com > Thread: Ignition Module Question NEW TOPIC NEW POLL POST REPLY
BlackMagic14
posted March 01, 2008 07:09 PM
Just got the hub, curious if anyone has tried the Ignition Module yet? any power gains on motor? Also will the Hub allow timing retard per gear for the prgressive nitrous setup. Basically anyone got any pros and cons on the ignition module
davisag
posted March 02, 2008 08:58 AM
hi
yes have the ignition module fitted, on my normally aspirated tuned motor, some advance in the lower end has gained power here and the rev extend now allows a new red line of 11.400 revs
BlackMagic14
posted March 02, 2008 03:39 PM
Dynotested or butt dyno?? I would like some power on motor but the biggest reason I am thinking of getting it is to retard timing so I can put a little bigger nitrous shot on it... But I am not sure if it has a static map that is the same for every gear or with the hub I can change the timing map for every gear. Anyone know?? Dubious I am sure you know come on chime in buddy
0.23830318450928 seconds processing time
