BIKELAND > FORUMS > ZX-14.com > Thread: K&N cleaner and oil on BMC Air Filter NEW TOPIC NEW POLL POST REPLY
TooHype
Go Hard or Go Home !!
posted February 24, 2008 12:53 AM        Edited By: TooHype on 24 Feb 2008 00:56
I was wondering if the K&N cleaner is ok to use on the BMC filter. Has anyone tried the combination. Is there a recharge kit for the BMC filter?
posted February 24, 2008 06:02 AM
schnitz has the bmc filter servicing kit, don't know what the difference is between that and k&n, but you might as well use the bmc kit, it was around 20 bucks. don't know if the oils they use would be simpatico with the k&n oil.
lietoome
posted February 24, 2008 07:21 AM
Same stuff, I've used it for years with no issues. Just make sure you clean the old stuff real well before you put the new oil in and you'll be fine.
0.75509095191956 seconds processing time
