BIKELAND > FORUMS > ZX-14.com > Thread: Anybody Tried 17-44 Gearing for Drag Racing NEW TOPIC NEW POLL POST REPLY
spyder636
posted February 06, 2008 07:50 PM
I weigh about 185 pounds and was wondering if anybody has ever used 17-44 gearing and how it worked out for them.
nightmare
ACP Racing
posted February 06, 2008 07:59 PM
Nope have not tried that one but I am running 16/43 and it works great for me! I am 5'9" and about 130lbs but my boy clean is running the same gearing and turning 6.0s and he is almost 300 pounds. Now Clean is still in the learners box but every now and then, he lets his nuts hang low and good lord he flies!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
BlackMagic14
posted February 06, 2008 09:13 PM
at 185 16/43 would probably be perfect
BlackMagic14
Scratch that it depends on what length yur bike is if it is stock length you wont do anything but wheelie
lietoome
posted February 06, 2008 10:10 PM
17/45 here.
creepdog
posted February 07, 2008 05:40 AM
i weigh 210,and im running 16/43.is that good or should i go up more on the back?
full trc pc k&n filter pulled flies stacks ign. advancer custom mapped
red1
posted February 07, 2008 07:27 AM
BlackMagic,
What length is your 14?
Red12/Blue14
creepdog
posted February 07, 2008 08:54 AM
got about a 6 inch stretch on it.
spyder636
posted February 07, 2008 09:27 AM
Im gonna have it out at about 64"
06 ZX14
Flies out
PCIII
Brocks Exhaust
Lowered and Strapped
Stretched and Geared (SOON)
BlackMagic14
posted February 07, 2008 11:09 AM
MIne is right at 66.5-67in 64 is abou tthe max with bolt ons
00Busa
Trying to go FASTER !
posted February 07, 2008 03:25 PM        Edited By: 00Busa on 7 Feb 2008 15:26
With it that long, don't you have problems spinning on the street ? I can see needing to be over 64" without some serious engine work. I get high 1.3s low 1.4s 60ft at 62.5".
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
BlackMagic14
posted February 07, 2008 06:08 PM
I weigh 300 pounds I can hook anywhere LOL my bike has some work done to it and I spray outta the hole so it has to be descently long
lietoome
posted February 07, 2008 06:18 PM
I dig the 17/45 only because I don't like the "wound up" feeling I get on the 16t. I've tried several combos, this one is the best for me.
9 in. Stretch.
zx14mike
posted February 07, 2008 07:44 PM
i'm with lietome...............i think the 17/45 or 16/42 ratio which are essentially the same are perfect for both street and strip.
bayou boy
posted February 08, 2008 08:48 AM
I RUN 17/44 I WGH 210, BUT GOT A WORK ALSO, I'M THINKIN GOING DOWN TO A 43
chavcat
posted February 08, 2008 05:31 PM
What is optimal gearing for stock wheelbase, lowered with rider 160 lbs?
zx14mike
posted February 08, 2008 08:31 PM
I'm stock wheelbase and i love 16/42.
00Busa
posted February 09, 2008 04:00 PM
I ran 5.90s at stock wheelbase with 16/40. The 40T pulled the wheel back a little farther and allowed me to leave harder. ( 172 lbs.) I'm 4" over now with 16/41.
'00 Busa / '06 14 /
fury
posted February 10, 2008 03:16 PM
Need assistance...
I am looking for a set of sprockets...
I am 200lbs and stock chasis.
Lookin to lift the front end up a little easier...
Not alot just a little...
Thanks for your input.
zx14mike
posted February 10, 2008 06:01 PM
I would go either 16/42 or 17/45 if you dont mind replacing the chain..............i'm 160 with a stock chasis and i've been running 16/42 since the i had 50 miles on the bike, Lietome is running 17/45 which is essentially the same ratio but requires a new chain, and he loves it as well.
With the 16/42 it will be a lot snappier and lift the front wheel easier but still cruise nice on the highway without being to buzzy or busy..........i think its the perfect ratio!
BlackMagic14
posted February 10, 2008 09:36 PM
I just cant believe no one has stated that when you run 17/4?? whatever you are intentionally making your chain longer which we all no longer chain =more rotating resistance may not be a lot but why add more when you can accomplish the same gear ratio and wheelbase with a shorter length chain. just food for thought
zx14mike
posted February 11, 2008 07:30 AM
BlackMagic, i did state that he would need a new/longer chain to run 17/45 gearing............however i didnt think the increased rotating resistance merited mentioning since i figured it would likely be canceled out by the decreased rotating resistance and increased chainlife from running larger sprockets.........i assumed they were small changes that would cancel each other out!
bigwillie3236
posted February 11, 2008 08:26 PM
Hey guys i weigh about 240 at 5'10 my 14 is 5 inches extended ,running 16/41s. I thought the 42s would be too much. what do you think?
BlackMagic14
posted February 11, 2008 09:39 PM
at 240 I would go 16/43
zx14mike
posted February 11, 2008 11:03 PM
I would tend to agree with Black Magic, at 240 with a 5 inch extension i would probably go 16/43...........the only caveat is you will for sure need an extra shift in the quarter and might want to consider more gearing so you are at the top of 5th gear when you cross the traps.
0.22228789329529 seconds processing time
