BIKELAND > FORUMS > ZX-14.com > Thread: timing curve NEW TOPIC NEW POLL POST REPLY
smiddy1
posted January 26, 2008 04:39 PM
timing curve
Does anyone know the stock timing curve for the '06? Also does the timing change per gear? At what throttle position is the timing retarded and in what gears?
Get on the line and drop it!
The Nitrous Advice Forum
posted January 26, 2008 07:06 PM
5th gear curve is optimum, the flies and timing are retarded :P
no seriously timing is retarded in 1, 2, 3 gears, and top end of 6th gear.
more so in 1st, and less retardation as you shift up.
smiddy1
posted January 26, 2008 08:31 PM
Thanks dubious, I was going to call Ivan and see what he had to say. I know muzzy would know but I hate calling there.
BlackMagic14
posted January 27, 2008 12:56 AM
There is no way to adjust the timing without a TIC or a ignition module other then the little timing sprocket that muzzy makes but the TRE has no effect on timing
lietoome
posted January 27, 2008 03:16 AM
I've heard +4 degrees works really well in the lower gears of the 14. Makes sense, my 12 loved the 4 degrees advance. Again, I was using the static Muzzy advancer on my 12. I'm not messing with the timing on the 14 until I can have it done by someone that knows what they are doing.
psycho1122
posted January 27, 2008 06:50 AM
Get a GI Pro with ATRE.
smiddy1
posted January 27, 2008 06:30 PM
There is no way to adjust the timing without a TIC or a ignition module other then the little timing sprocket that muzzy makes but the TRE has no effect on timing[/quot
You've got me wrong, I just need to know what the timing curve is. I'm not changing anything as of right now, and when I do, I'll do it with a ignition module from dynojet. I just wanted to know about the retard in the lower gears and lower throttle positions. It seems to be a pain in the ass how they do this.
posted January 27, 2008 07:50 PM
Matt, the TRE tells the ecu that the bike is in 5th which is the best ignition and flies in timing curve.
The tre effects timing by using 5th gear ignition timing map.
87gtNOS
posted January 28, 2008 12:53 PM
I have TRE 006A and have slotted my pickup to an estimated 4 deg advance.
01 ZX12R
posted January 29, 2008 06:48 PM
Both ! ...?....!
0.22383999824524 seconds processing time
