BIKELAND > FORUMS > ZX-14.com > Thread: Mr turbo stage 1 NEW TOPIC NEW POLL POST REPLY
duncan
posted January 13, 2008 02:48 PM
Mr turbo stage 1
How much hp and torque does a stage 1 mr turbo make? A friend of mine is getting one put on his 08. Also how much boost can he push through the motor on pump and race fuel?
kawabunga
Cogswell Cogs Installed
posted January 13, 2008 03:21 PM
With 3-5 pounds of boost you can expect 230-270 HP on pump gas. Drop your stock compression from 12.5 to1 to a lower 8 - 8.5 to 1 and and race fuel you can run more boost. More boost more HP. As far as torque numbers, somewhere in the 145 to 155 range depending on dyno's. Stage 1 should be ample enough for just the street rider and fuel availability as well as cost.
0.21598291397095 seconds processing time
