BIKELAND > FORUMS > ZX-14.com > Thread: that did not last long NEW TOPIC NEW POLL POST REPLY
davisag
posted January 13, 2008 06:40 AM
well fitted my power commander ignition module a few weeks ago, only use it had was setting everything up on the dyno, week later come out this morning , start engine, would only idle a couple of secs before cutting out, and any attemt to give it throttle resulted in back fire and then cut out
disconnected ignition module from power commander and everything fine, and yes i did have a good earth
FASTESTbusaAROUND
I eat Fish...
posted January 13, 2008 07:30 AM
Idle speed sounds too low. Has to be at least 900 or more.
FYYFF!!!
3boysand3bikes
posted January 13, 2008 08:17 PM
I had the exact same thing as you.... I even would be able to ride for a few minutes and then it would just cut out. This happened 5 or 6 times. I could unplug the PC and plug in the stock wires (while burning my hands...) and it would run great. I called Dyno Jet and they were going to have me send in the PC. I figured I would try a few things first.... which I did. The first thing I did was re-do all of the wiring. That included the ground wire as well as the PC harness. I wanted to make sure I had no pinches or melted wires on the harness as it was routed near some heat on the motor. I made sure that it was run perfectly up to the front fairing. I then ground the wire directly to the frame... (Some people run it to their battery) Since I did those changes, I have not had any further problems. (Over 5000 miles later.) I realize that you feel comfortable with your ground... maybe just a change of location?? Just letting you know of me personal experience.... Good Luck!!
FASTESTbusaAROUND
I eat Fish...
posted January 13, 2008 08:39 PM
Ground right to original battery ground -- that's the best place. The only issues I ever had like that, were when the idle speed was et below 950.
FYYFF!!!
davisag
posted January 14, 2008 01:13 PM
hi
well the ignition module will only go in the right hand side of the fairing as the wires are not long enought to reach unlike the pc which can go under the seat so there is no chance of the ignition module earth reaching the battery earth
ninja12
posted January 14, 2008 01:58 PM
splice an additional Ground wire into it.
FASTESTbusaAROUND
I eat Fish...
posted January 14, 2008 02:05 PM
Exactly - simple job. Make sure that you SOLDER the wire when you add it.
FYYFF!!!
kimski2001
posted January 14, 2008 04:01 PM
question about the module?i called dynojet today and asked about it and they said its really only good if you have a power adder.and if no power adder whats a good setting?
1st14injax
0.41064691543579 seconds processing time
