hardcoremass
Powerhouse
posted January 12, 2008 09:53 AM
PC ignition module
Recently installed Muzzy map on PC, software showed RPM status, % of fuel change, and what appeared to be igntion feedback . The ignition feedback remained at 0 throughout full RPM range. The module face has a green led showing it is configured to the PC. Is there a way of monitoring the output of the module? Bike starts and revs much crisper than before the install, would be nice to know exactly what changes are taking place!
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
posted January 12, 2008 11:01 AM
As I understand...
It will not alter stock timing unless offset timing is programmed to do so.
If it shows 0, then you have not entered any offset values, ie, retarded, nor advanced the timing from stock.
I don't think neutral will take any different offset, the bike must be in a gear, as the timing changes can be programmed for each individual gear if you have th hub and GPS set up.
If you do not have the GPS input hooked up, it will alter stock timing the same for every gear. If you have an LCD display you could monitor it, otherwise a dyno and laptop are required to monitor ....
Pretty sure thats how it works...
Call dynojet, they have tech advisors who KNOW exactly how it works and set up.
hardcoremass
Powerhouse
posted January 13, 2008 01:01 PM
Thanks for the input Dubious, the bike remaining in neutral never came to mind. Will give Dynojet a call to confirm.
