BIKELAND > FORUMS > ZX-14.com > Thread: zx14 second fan NEW TOPIC NEW POLL POST REPLY
zx14bert
posted January 06, 2008 04:13 PM
zx14 second fan
Does anyone have good pics or a kit to install a second fan on a zx14
posted January 06, 2008 04:49 PM
i saw someone on this site added a second fan by modifying the mount on the second original fan, but who needs it
fastestbusaaround
I eat Fish...
posted January 06, 2008 05:59 PM
Exactly -- it doesn't run hot enough to warrant that anyway...try a C14; with dual fans, it still kicks the piss out of you heatwise...
FYYFF!!!
posted January 06, 2008 08:56 PM
+1
In Florida heat, my ZX14 required no second fan or such.
joemugg
posted January 06, 2008 09:16 PM
I bought a second radiator off ebay from a crashed bike. I'm taking the fan from it, cutting the mounting tabs off the crashed rad and welding them on the right side of the good rad. Then I'm going to replace both fans with aluminum fans from Muzzy. That should keep it as cool as it could ever be.
'97 GSXR600 street sweeper
posted January 06, 2008 09:42 PM
why?
kawabunga
Cogswell Cogs Installed
posted January 07, 2008 03:04 AM        Edited By: kawabunga on 7 Jan 2008 03:13
I recommend everyone checking the link below and reading up on the tech info. No need to modify or add fans to your cooling system. This is the best coolant out there. Waterless and doesn't require pressure. Boil over point is 370 degrees with no pressure and or 2-5 psi of pressure, lifetime coolant, never have to change, increases horsepower, no more hot spots, increase spark with no worries of detonation etc.... I use it all my serious street and race builds....best kept secret out there. Please take the time to read ...you won't regret it.
http://www.evanscooling.com/main27.htm
NinjaNick
'08 ZX14 (Blue)
posted January 07, 2008 02:18 PM
joemugg
posted January 07, 2008 04:08 PM
I overheated my 14 in north Georgia in November sitting in traffic for over 30 minutes. Ambient was not much over 70, if even, and the damn thing went berserk flashing that it was overheating. My brother has a 'busa that has overheating problems and he actually melted his stock plastic fan and then swapped in the Muzzy. I figure the second unit with the Muzzy's is an easy way to fix the problem for good. Especially when every board I visit has numerous posts about people having overheating issues. An ounce of prevention and all...
posted January 07, 2008 04:26 PM
very interesting, did you use the flush pre treatment
fastest-14
Fastest -14
posted January 07, 2008 04:30 PM
If anyone who has decided to do the second fan or is thinking about adding the second fan, how would you go about plugging it or what would you plug it into?
posted January 07, 2008 06:48 PM
we have tried to overheat our ZX14's in Florida. I let mine idle forever on black tarmack in the scorching heat of our mid-summer. No heat problems/no drama/angels playing harps in the background after I shut it off.
Silver08
posted January 07, 2008 08:31 PM
which NPG do you use?? and did you use the prep first??
08 ZX14
mink
posted January 08, 2008 03:59 PM
im adding a second fan because my pistons have grown up over the winter
ghostman
posted January 08, 2008 04:28 PM
Maybe that's why the RED ones were so special.
I'm There Whether You See Me Or Not.
fastest-14
Fastest -14
posted January 08, 2008 05:28 PM
Once again, does anyone have an answer to this particular question?
kawabunga
posted January 08, 2008 06:06 PM
I use the NPG+ in all my applications with great success. No need for a second fan. In all of my liquid cooled engine builds I use no cleaner or prep because of total disassembly, I soak everything coling related with hot alcohol and let drain and air dry for a 2 days. The radiators I flush with hot distilled water, drain and let air dry. This prevents any water contamination upon installation of the NPG+.
BlackMagic14
posted January 08, 2008 09:49 PM
Second fan is a must witha big bore if you want to ride on the street!!! If i were you I would wire the second fan to a handlebar switch so you can turn it on and off whenever you want..
IMO.
joemugg
posted January 09, 2008 09:12 AM
I haven't checked amperage draw yet, but i'm wiring my two fans together (series or parallel depending on current) so they will work in tandem using the factory temp switch. I'll let you know when I check them.
posted January 09, 2008 02:44 PM
get ready for the smell of burning wire
ninja12
posted January 09, 2008 05:15 PM
use a relay triggered by the original fan.
russ8526
posted January 09, 2008 06:20 PM
I have added a secound fan that i got off E-bay for $20 and bought a splicer from auto zone for .30 cents and splice the two together and have put 5200 miles on the bike with no problems.
2007 zx-14 Limited
Brocks Alien Head
BMC Race Filter
PClll w / Track Map
Flies Removed
16 T Front Sprocket
Speedohealer
Fender Eliminator
ninja12
posted January 10, 2008 07:34 AM        Edited By: ninja12 on 10 Jan 2008 07:35
What type fan did you add?
Can you post a picture?
fastestbusaaround
I eat Fish...
posted January 10, 2008 11:33 AM
To all of those who have overheat issues -- has anyone bothered to check to see if they have air in the system or flushed the rad? I've never had any issue with heat whatsoever on my ZX14's.
FYYFF!!!
russ8526
posted January 10, 2008 04:42 PM
it was a stock 14 fan turn upside down on the right side of radiator. fit like it was meant to be there. the next time i drop the radiator for any reason i will try to post pics.
2007 zx-14 Limited
Brocks Alien Head
BMC Race Filter
PClll w / Track Map
Flies Removed
16 T Front Sprocket
Speedohealer
Fender Eliminator
0.34006786346436 seconds processing time
