BIKELAND > FORUMS > ZX-14.com > Thread: synthetic oil??? NEW TOPIC NEW POLL POST REPLY
duncan
posted December 31, 2007 06:34 PM
synthetic oil???
Looking for opinions on when to change to synthetic {how many miles} and what's the prefered weight and brand most here are using.
Wheelie
Old Man
posted December 31, 2007 06:50 PM
Motul 5100 10-40 at 200 miles.
wee
fastestbusaaround
I eat Fish...
posted December 31, 2007 07:22 PM
Another oil thread?
FYYFF!!!
jarhead
posted January 01, 2008 10:38 AM
There is a ton of info out there but any good motorcycle oil will be fine. I don't endorse but quite honestly think there is very little difference between regular full syn and moto full syn. That being said I use Castrol R4 full syn.
posted January 01, 2008 10:41 AM
1000miles...RedLine 10-40 synthetic
lietoome
posted January 01, 2008 03:44 PM
mobile one
posted January 01, 2008 06:17 PM
Another oil thread?
only one more :P
posted January 02, 2008 08:57 AM
2000 miles motul 300v 20w-50
jeff martin
Pro (closed)
jamming
posted January 02, 2008 09:34 AM
Rotella 5w-40 for the price its great or mobil 1..Tons of info already here and of course the internet..www.thetruthaboutoil.com
i play with boats my wife plays with my dingy.
  Ignore this member    Click here to visit jeff martin's homepage.
Rifleman_duce
Yeah, that's what she said
posted January 03, 2008 11:42 AM
I run Castrol Syntec 10-W30...
one recomendation is to run standard oil for the break in period... the rings need to seat with the cylinder walls... and for that to happen there needs to be a little wear between the two... if you run synthetic oil, the oil is too slippery for the proper seating to occure and you will loose a small amount of compression and bHp...
I read an artical on "Blast" breakin's by Motoman and he basically says all that first 1000 miles below 3800 RPM and next 5000 below 5000 RPM is bull... get the engine started and TOTALLY warmed up, get on the track and wack it hard.... then slam the throttle closed, then wack it hard, then slam closed.... half a dozen to a dozen times... and your rings are seated, and seated better then any other way. Perfect seated rings means more compression, means more bHp
]Need to know how to install your Rifleman's 1/5th throttle insert? click me
For more info on a sticky grip (not enough cable slack) click me
  Ignore this member    Click here to visit Rifleman_duce's homepage.
ZXfreak
posted January 03, 2008 11:50 PM
Hi all, new to the forum here, I just picked up a new 2007 ZX-14 the other day, and I am currently following Motoman's advice on break in, however I dont run it up to redline, only about 6000 rpm, and only a few times. Mainly I just try to accelerate briskly, modulate throttle and go through the gears. Motoman says to change oil after the first 20 or 30 miles to non synthetic 10w-40 CAR oil, then again at 1500 or so miles to whatever you like, I plan on changing to full synthetic, probably Motul oil or something similar. I understand why he recommends non synthetic for the first oil change, I would like to get some feedback on why CAR oil, and not motorcycle oil. Any ideas?
2007 Superduke
BlackMagic14
posted January 04, 2008 12:58 AM
Any synthetic fine as long as it doesnt have any of those Energy saving molecules or whatever they are called. And by the way Brock no longer recommends the mobil 1 5w-30 cause they added those energy saving molecules
Tool Man
posted January 04, 2008 06:40 AM
I did too...Car oil does not have the additives for the transmission in it. (High shear strength)
So... it allows better break in...ie. lapping to take place. That is all done pretty quickly. Change a new bike oil early and often..I did @ 50 / 200 / 1000 with car oil and 3000 with Mobil one. ( it get all the little shavings out / normal)
After that every 3000 with Mobil one. Just did the valves and the cams look mint.
The banks are failing..
The banks are failing...
Invest in Ammo
tater
Shakin off the Haters
posted January 04, 2008 07:45 AM
about 2500 miles i switched to amsoil 10w 40 synthetic and i am lovin it!
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
0.31069183349609 seconds processing time
