BIKELAND > FORUMS > ZX-14.com > Thread: Chain links and Drag Tire NEW TOPIC NEW POLL POST REPLY
spyder636
posted January 03, 2008 06:16 PM
How many links do you need for 6 inches stretched, and would you recommend a o-ring or non-oring chain?? Is the shinko ultra soft really the best drag tire since it is a little on the heavy side???
smokinzx14
posted January 03, 2008 06:29 PM
non oring 140 links ( cut to fit ) Shinko 003 Usoft ..
serius blk
posted January 03, 2008 08:22 PM
does the u soft say it on the side of the tire. I think i bought the other one. mine looks the part but will not stick at all. It just says oo3. I ve lowered the psi to 15 and it still spins. Perhaps its not the one i thought i was buying.
spyder636
posted January 03, 2008 08:37 PM
Is there any reason I would need a chain over 140 links if I used 2-8 swingarm extensions
posted January 03, 2008 08:43 PM
With gearing @ 64inch wheel base the chain is around 136 pins/links...I guess if you need to be more than 64"
spyder636
posted January 03, 2008 09:49 PM
posted January 03, 2008 10:10 PM
sidewall will state "R-003RR " and " u-soft 003"
BlackMagic14
posted January 04, 2008 01:20 AM
IT WILL SAY USOFT if it does not then you got the wrong tire
0.23811197280884 seconds processing time
