BIKELAND > FORUMS > ZX-14.com > Thread: adams straight link????? NEW TOPIC NEW POLL POST REPLY
jessejames82
posted December 27, 2007 01:29 PM
if anyone could chime in on who bought these it would be great...i want to get the adams straight link for my zx 14 to lower it and to get more clearance... question is that do i need to have the super slammers or can i use my muzzys links to get 3 inchs ground clearance... i have the muzzys now and with the bike strapped it is less then 3 inchs... need input
Orient Express Rider
SuperSport ZX 14
6.000 8th mile
ninja12
posted December 27, 2007 02:24 PM
Also any comparison to the pro-link.
Which will do the best job of getting low and getting out the hole?
kawasaki_rick
posted December 27, 2007 03:01 PM
I think on psychobike they said you had to have certian adjustable links for them to work.
kawasaki_rick
posted December 27, 2007 03:06 PM
Adjustable busa links seem to be the ticket.
billeason
posted December 27, 2007 04:13 PM
The stk links work,but the adj busa links work the best set at about 5-3/4 of lenght center to center, We have the best leave this way just make sure you have the clearance for the fuel pump, bill
bill eason
posted December 27, 2007 06:26 PM        Edited By: CrotchRocket on 27 Dec 2007 18:28
The optimum performance and adjustability of your rear suspension is to get an Ohlins or Penske Drag shock made with your weight, bike weight, motor horse power, proper spring and a shorter shock shaft using the OEM dog bones keeping the factory geometry!!!
Setting a bike up this way is a must with a turbo or big motor with nitrous!!!
jarhead
posted December 28, 2007 02:39 AM
I was going to go this route and talked to Coby, he said they used Busa links with .75 spacers. I then talked to Terry Mac about them and he said there was some concern with the bike hooking well out of the hole but then breaking the back tire loose. I am not sure if anyone that has them could help out with whether they have had that problem or not.
mark524
posted December 28, 2007 10:23 AM
i don't have the adams straight link, but one made by a guy named Zook on psychobike. i think they are the same. but anyway, i use the stock dogbones with it and it's about like having it in the middle hole of a 3-hole link. the bike is 64". basically it changes the geometry of the suspension to make the shock stiffer. it works very well as an alternative to an expensive aftermarket shock. i needed it because i am a big dude and couldn't get the shock stiff enough. if you have a modified oil pan and sidewinder you can get pretty low, and use the straight link to keep it stiff enough to not bottom out. but if you get too stiff, it will spin.
and yes you will need a lowering link that is adjustable, because the 3-hole links set on the lowest setting will have the other two holes sticking down. with the revised geometry of the straight link, the link will hit the frame.
R Muzzy
posted December 28, 2007 10:59 AM
MUZZYS also has a flat link. It is designed to be used with the MUZZY Dry Sump and aftermarket pans. There are two links available.
0.226567029953 seconds processing time
