BIKELAND > FORUMS > ZX-14.com > Thread: How many links? NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted December 27, 2007 01:14 PM
How many links?
I got a great price on some 6 inch extensions for the 14. How many links does the chain need to be to run out the full 6inch? I've tried searching the forum but didnt have any luck.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
ninja12
posted December 27, 2007 02:30 PM
Don't know but many of the bolt-on can't use the full extention IF you want to maintain the rear brake. You may want to check before you get too excited about the 6 inches.
The brake support will only work out to about 4 inches. hope you got the good ones that go all the way back.
kawasakijockey
posted December 27, 2007 02:37 PM
OK, I see. These are Yani Shiki.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Tool Man
posted December 27, 2007 04:12 PM
Stock is 116 links...Pitch on a 530 chain is .625 inchs pin to pin.
So... 6" / .625 = 9.6 * 2 = 19.2
So....A 6 inch extension wiil require 19.2 links with stock gearing, add or subtract your gearing selection +1 for one tooth bigger rear and so on...
Here is some info on spockets and chain http://www.gizmology.net/sprockets.htm
The banks are failing..
The banks are failing...
Invest in Ammo
zx14kawboi
just wanna be fast
posted December 27, 2007 06:21 PM        Edited By: zx14kawboi on 27 Dec 2007 18:22
brake line will work; mine does but it wont hook up at all on the street. i had to bring my roaring toys ext . in as far as i could just to find traction .i think it is about 3" over now maybe 4
posted December 27, 2007 06:34 PM
Buy a 140 pin chain and you'll probably use about 134-136 pin with 1 down in front sprocket and 2 up in rear sprocket...
blackbullet76
posted December 27, 2007 07:06 PM
I had mine at 6.5 inch stretch, 1 tooth down in the front and 3 up in the back. I put it back stock after the racing season was over with. I got an aftermarket 150 link dragchain for this setup. I can't remember how many links I removed, but it wasn't many. Be careful on the street, traction in 2nd and 3rd is hard to come by
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Tool Man
posted December 28, 2007 05:23 AM
Ya....math is hard, Do what he said ^^^
Invest in Ammo
posted December 28, 2007 07:43 AM
on schnitz they have chain and sprocket combos that tell you the needed info
0.24484992027283 seconds processing time
