BIKELAND > FORUMS > ZX-14.com > Thread: Top Speed Runs to Fool Speed Limiter?? NEW TOPIC NEW POLL POST REPLY
Cajunboyz
posted December 07, 2007 09:24 AM
I have a seedohealer for my 14. How are the ones which are doing hi top end runs setting there speedohealer?? I noticed that when its set -% above -12% & up the bike runs rougher in the 2800-3100rpm range.I had it at -20% but brought it back to-14%
I hear some using the km/h ?Just wanting some input ,thanks
Seth ZX12r UK
posted December 07, 2007 10:15 AM
juse set it to convert mph-kph or vice versa if your just using it for lsr, then disable it when not
  Ignore this member    Click here to visit Seth ZX12r UK's homepage.
BobC
posted December 07, 2007 11:35 AM
Set it to convert kph to mph and it gives you a 300mph speedo' on the inner scale. Like Seth said leave it in transparent for the road.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Cajunboyz
posted December 07, 2007 12:10 PM
So theres no limiter on the kph scale. & leaving it in transparent for road,? Is this something you just recalibrate after the top end runs. Thanks for any help, I'm just rying to understand this part???
madkawboy
posted December 07, 2007 07:10 PM
I just ground off one of the speedo pick up points on the counter shaft nut. The nut is still safe to use. It worked for me at Maxton
2007 ZX-14
Stock Wheel Base, footshifting, pump gas
5.94 @ 128 mph
1.50 60ft
BobC
posted December 08, 2007 12:42 AM
It's an illusion. In reality the speedo just has a massive under-read, coinciding with the conversion kph/mph, and the ECU speed limiter is never reached.
Stock wheelbase
0.20196080207825 seconds processing time
