BIKELAND > FORUMS > ZX-14.com > Thread: Oil Leaks on 2006 14's NEW TOPIC NEW POLL POST REPLY
Nelson Taylor
posted December 07, 2007 08:31 AM
I better go and check mine out before I head out to work.
8700miles and i haven't noticed anything yet.
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
posted December 07, 2007 09:21 AM        Edited By: stevewfl on 7 Dec 2007 09:21
Is the valve cover gasket one piece?
I put a "replaced parts" list of what all it took the 2nd visit to the Kawi the shop for me.... maybe that will illustrate the parts
http://www.bikeland.org/board/viewthread.php?FID=27&TID=26799
But you know what, its not anywhere close to accurate to say "all 2006 14's have this problem"
I know of many many that don't, but for the ones with the problem I've yet to see one with a permanent fix.
zxplosion
posted December 07, 2007 10:24 AM
I gave my dealer your parts list, he said they would try them and see what happens.....tick-tock-tick-tock........................
2006 ZX14R/ZX-PLOSION
The more we sweat in peace, The less we bleed in war! USMC
MJ
posted December 07, 2007 02:33 PM        Edited By: MJ on 7 Dec 2007 14:35
Is the valve cover gasket one piece? Or does it have cams seals too. I have not taken the valve cover off, bc i have not had any problems. I have about 3700 miles on it so far.
I've got about 3500 miles on my 06 14 and it has several leaks. The flush mount oil passage plugs on each side are seeping...my valve covers leaking slightly...and I have a slight leak from behind my water pump, not sure if its oil or coolant. But my bike never leaves a drip on the ground....doesn't use any fluids...and if I didn't check my bike over carefully every so often, I wouldn't even know they were there. Every kawi I've ever had has leaked somewhere...but they've always been fast and reliable. Don't let a seep here or there worry you. More than likely they'll never get worse, and won't ever present a problem
posted December 07, 2007 06:09 PM
no probs here
posted December 07, 2007 09:14 PM
no probs here
many don't have probs.
posted December 07, 2007 10:20 PM
I was going to say, mine has never leaked,............ but then it will. so I won't.
posted December 08, 2007 07:03 PM
no need to knock on the wood for sure!
zxplosion
posted December 10, 2007 11:38 AM
GOOD NEWS, GOOD NEWS..........Kawasaki Motors notified my dealer that there is a problem with some of the 2006 models. They told the dealer to place a certain type of bond/sealant on the gasket, replace the o-rings and replace the current bolts with longer ones so that the head cover can be tighten down better! Guess the BEAST will staying in the stable for a lot longer while.
qwick
posted December 10, 2007 08:06 PM
Last month Kaw told the dealership here that there are no known problems related to oil leaks on any year model ZX14's. I'll be over that way tomorrow so I'll stop back by and see if they have received any revised reports on it.
posted December 10, 2007 11:06 PM
nothing about the sealant, but the other stuff was said to my dealer the SECOND time it went in for that prob...and a list of new parts suggested by Kawi including the bolts and o-rings. watch it after 5-6000 miles and check and see if the prob is back.
maybe the sealant is the solution. the bolts and o-rings on mine weren't (after 5-6000 miles problem back). but that seems weird on a head gasket about the "sealant" thing anyway?
BIKELAND > FORUMS > ZX-14.com > Thread: Oil Leaks on 2006 14\'s NEW TOPIC NEW POLL POST REPLY
0.24794411659241 seconds processing time
