BIKELAND > FORUMS > ZX-14.com > Thread: sidewinder installed ( brake switch shorting out) NEW TOPIC NEW POLL POST REPLY
northmedic
posted October 27, 2007 09:34 AM
Hi gang
installed my brocks sidewinder last night and the first time i hit the back brake it pop the 10 amp fuse noticed that the brake switch is pushed hard againts the frame when you put the spacers in to support the exhaust any help would be great . ????
I,ll be right back
northmedic
posted October 27, 2007 10:18 AM
well not sure if it was the correct Fix but it works bottomed the switch out and cut and shortened the spring
I,ll be right back
northmedic
posted October 27, 2007 11:37 AM
Now the brakes are locking on after a 10 min ride argh this thing is more trouble then its worth didnt even use the back brakes on the way home and by the time i got in the drive way they where almost at a full application i did bleed the brakes didnt fix it
I,ll be right back
posted October 27, 2007 12:07 PM
The pipe or hanger is depressing the brake pedal, and rubbed/ burned the brake light wire.
I have had your .42mkg/mm fork springs, 11.6 kg/mm shock spring, vortex 43 tooth sprocket and dial plate for sometime now.
You still want em ?
northmedic
posted October 27, 2007 12:49 PM
yes Lyle i do want them i sent you a couple of Pm 's on that will call you thanks
I,ll be right back
smokinzx14
posted October 27, 2007 01:36 PM
Email or call Brock ASAP ... He will take care of you don't worry ....Mine caused the switch to get kind of bind in it but it worked fine .. I had to reset the brake arm Adjustment so not to hit the pipe ...No problems after that ...Smokin ..
iflyems
posted October 27, 2007 04:49 PM
Simply do what I did, unplug the rear brake switch. You don't need it anyways. You'll still have to reset your rear brake lever so it doesn't hit.
badzx14
needs more power!!!!!
posted October 31, 2007 01:40 PM
I got the muzzy sidewinder from lee(smokin) and it works great,never had any problems with it.
northmedic
posted October 31, 2007 02:38 PM
all the minor bugs worked out re routed the brake switch wire and now have rear brake light ,
I,ll be right back
0.28058815002441 seconds processing time
