BIKELAND > FORUMS > ZX-14.com > Thread: Motorcycle Tech Question....Brake related NEW TOPIC NEW POLL POST REPLY
nabrxx
posted October 24, 2007 04:46 PM
This is not zx-14 related.. My clutch lever needs to be pulled in much further than it used to to disengage the clutch on my V-max... I must be losing fluid ...I think...I havent noticed any leaking though. ...Can I simply remove the cover from my clutch lever fluid reservoir and add some brake fluid without having to bleed anything?...I realise this is not a "fix"...just a band-aid so I dont get stuck....Any insights are appreciated.
What we don't understand, we can
make mean anything... src="http://www.bikeland.org/board/i
mages/smilies/smile.gif" border=0>
MasterBlaster
posted October 24, 2007 04:59 PM
Sure air wont get in the system by adding fluid. However the fluids, brake and clutch should be changed annually. Clean fluid is almost clear, as it gets old it turns dark. Brake fluid is hydroscopic and over time absorbs moisture. Handy item for changing and bleeding the system is a Mighty Vac, about 30 bux at Auto Zone.....TB
nabrxx
posted October 24, 2007 05:31 PM
Thanks ....Im giving it a shot this weekend then!!!
Obba
posted October 25, 2007 01:46 AM
Good demonstration on how helpful and knowledgeable the guys & gals... are here in the ZX14 forum are here to help, even though you own the comp!
I raced a Vmax once and even though he looked like an old codger, he sure as hell opened it up....
Beat him though
nabrxx
posted October 25, 2007 07:26 AM
I own a 14 also Obba...but you are correct...these dudes know their shit.
SteddyTeddy
posted October 25, 2007 08:54 AM        Edited By: SteddyTeddy on 25 Oct 2007 09:55
I have to change out the clutch fluid on my ZRX at least once a year. It gets dirty realy fast and will affect the feel of the clutch.
0.24769115447998 seconds processing time
