BIKELAND > FORUMS > ZX-14.com > Thread: Installing a teather switch NEW TOPIC NEW POLL POST REPLY
march686
posted October 23, 2007 04:41 PM
I'm looking for some help installing a teather swithc that I will need to make passes at the drag strip. I tried (unsuccessfully) to install one on my 636 and would like to get it right this time. For those who have, is the necessary switch a normally open or normally closed? Also which wire did you splice into. On my 636 I tried using the lead to the handlebar swich but the the bike keeps running with the teather removed from the swich. According to my multi meter only 6 volts is traveling through this wire and can only conclude that the switch needs 12 volts to switch. Any advice from those that have installed teathers on their 14's would be great.
smokinzx14
posted October 23, 2007 04:49 PM
Right handle bar .... the one with the kill switch ....Follow the wires down to the plug for that switch .... Cut and splice into the red with silver tracer....
march686
posted October 23, 2007 05:02 PM
Normally open switch or normally closed? Any particular brand? I tried a Gunnar on the 636 with no luck
smokinzx14
posted October 23, 2007 05:07 PM        Edited By: smokinzx14 on 23 Oct 2007 18:09
Schnitz >>>>> http://secure.mycart.net/catalogs/catalog.asp?prodid=4890366&showprevnext=1 ............plugged in it's closed ... pull out it's open
march686
posted October 23, 2007 05:41 PM
Thank you, just the info I was looking for. Slick switch housings by the way. A question about the toggle brackets, can you get the bracket with a 3 way switch instead of a 2 way?
0.20924997329712 seconds processing time
