BIKELAND > FORUMS > ZX-14.com > Thread: FLYS OUT WITH NOS NEW TOPIC NEW POLL POST REPLY
bayou boy
posted October 22, 2007 01:43 PM
FLYS OUT WITH NOS
CAN U TAKE UR FLYS OUT AN STILL HAVE NOS ,TRYING TO FIND OUT IF IT WILL AFFECT THE BIKE.
jdzx14
posted October 22, 2007 01:47 PM
I am pretty sure thats a big yes.. will not affect anything. As far as i know the files just keep the power down in the lower rpms for rideablity and safety. Dont hold me to that though.
2007 Black ZX-14
billeason
posted October 22, 2007 02:01 PM
Works better without flies w/nos. Just make damn sure you have enough fuel added. With small shot/no flies and a good map these bikes will run!! an they will stay together, in the process, Just dont get greedy with stock pistons, We have a half dozen bikes with dry 40 shots that have been running two race seasons with little more than oil changes. Bill...
bill eason
wrongway
posted October 22, 2007 02:22 PM
is that 40 rear wheel hp ? I ran 2 x .024 and bumped it up to 2 x .028 jets. Is that too much for a stock motor ?
Roy
bayou boy
posted October 22, 2007 03:47 PM
i got je pistons, 65shot
posted October 22, 2007 08:54 PM
I am running muzzy dry shot , 38 was the biggest jet the kit came with, mine is running a 42 now, with 20% fuel added.... on brocks map.
38=50 hp, 42 = ??? 60????
Haven't dynoed it since.... wego2 o2 meter is my friend.
At first I was running brocks track map, but noticed it was leaning out at top speed with the nitrous, and ram air at WFO speeds.
Now i run his maxton map with 20% added on the gas,
I have been running the hub, and the 2 map is activated with the solenoid button( start button) simultaneously.
No flies
No problems!
I don't hit the juice below 7000 rpm anyway. It's not good to use it at lower rpm, DETONATION and NOS kills motors QUICK, and don't wish to test the theory with my bike.
bayou boy
posted October 23, 2007 05:03 AM
right, that's what i have a 42 jet, i hit my spray in third gear, i wonder once i take my flies out, will i have to get it dyno again.
Stalwart
posted October 23, 2007 06:19 AM
At 7000 rpm the flies are open anyway so it won't change anything.
Stuart
Ridin' the Trump train.
posted October 23, 2007 06:23 AM
flies out will run lean at cruise rpm.
If you street ride it, I would have it mapped.
tslewisz
posted October 23, 2007 06:49 AM
Dubious is right about the risk of detonation hitting the juice at low RPM's. That isn't the whole story, though. Thing is, when you hit the button, it's going to add a fixed amount of juice, regardless of the RPM. At a lower RPM, the cylinders will have a longer time to inhale the nitrous. That's going to increase cylinder pressure and torque dramatically. Not good on the bottom end.
On another note, I must have missed the post, dubious, where you talked about how you smoked your indicators and tail light. Fill me in?
wrongway
posted October 23, 2007 07:41 AM
No flies
No problems!
2x .028 is equal to 1 x .040 jet , so I am pretty close to that. I have 17 in the 100% column of the PC3 and I see an AFR of 12.5.
I think I am more than 20 % since i had negative numbers in the PC3 when I was motor only.
Roy
nightmare
ACP Racing
posted October 23, 2007 08:30 AM
My flies are gone and when I was running nitrous, I was running just fine! Just make sure you have the correct map installed.
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
billeason
posted October 23, 2007 04:08 PM
Roy
Sorry wrongway, i meant to say 40 hp at rear wheel, with the muzzy kit, Thats with 36 jet but spray bar position is cridical for some reason more so than other systems.If it set like intructions works very good. I would say you may be on the hot side of things on 28s but would ask smokin on here i think he has some exp, with daul set ups, bill..
bill eason
0.2147262096405 seconds processing time
