BIKELAND > FORUMS > ZX-14.com > Thread: Removing Flies NEW TOPIC NEW POLL POST REPLY
hardcoremass
Powerhouse
posted October 19, 2007 03:03 PM
Removing Flies
Has anyone besides myself had any difficulty removing screws. Don't really care to strip them out, any suggestions? Have read that some have tapped on end of screwdriver with mallet, but I do not want to bend shaft.
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
lietoome
posted October 19, 2007 03:07 PM
try heating the screws with a soldering iron. Dont use a mallet, you risk bending the bar they are mounted on which is a COMPLETE PITA.. Use a 10" #2 crosstip and seat it into the head of the screw. Mine came out really easily. I also taped the plates to ensure they stayed closed.
jeff martin
Pro (closed)
jamming
posted October 19, 2007 03:14 PM
Ditto, Heating them with a soldering gun works really well..Just hold it on the screws for about 15 sec and they come right out..And if you have a good japanese standard screwdriver set it also works better...than a american standard set...Just use one of those cheap, takes forever to heat up guns its easyier to reach the screws..
i play with boats my wife plays with my dingy.
  Ignore this member    Click here to visit jeff martin's homepage.
hardcoremass
Powerhouse
posted October 19, 2007 03:20 PM
Thanks for the quick replies fellas. Expected nothing less from all who post on this site. A+
posted October 19, 2007 04:29 PM
ya heating the factory locktite a little and the screws will give with little effort.
BUT also insure you use a fresh correct size screwdriver
0.28890609741211 seconds processing time
