BIKELAND > FORUMS > ZX-14.com > Thread: power commander NEW TOPIC NEW POLL POST REPLY
getusome
smokin
posted October 02, 2007 04:26 AM
power commander
do all 2007 powercomander come with the WOT option or is it sold seperatly . is anyone running this with any luck?
CJ
ZXLNT
posted October 02, 2007 09:17 AM
huh???
FasterThanStink
posted October 02, 2007 12:05 PM
The WOT option is stock on all ZX-14's. It is accessed via a rapid downward twist of the right hand-grip until the range of circular motion is terminated.
That's what gets you.
87gtNOS
posted October 02, 2007 05:22 PM
I think he means the dynojet shifter thingy.
go look on powercommander's website...everything you need to know to get started is there!
01 ZX12R
getusome
smokin
posted October 03, 2007 04:20 AM
Thanks 87 . running 4 into 2 muzzy carbon fiber pipes. having back fire at downshift . does your pipe do the same
CJ
87gtNOS
posted October 03, 2007 04:34 AM
Buy a TRE006a (for flies out) and no more backfires, just smoothness! If your flies are still in, TAKE EM OUT!!
I have some maps for slipons that work nice.
01 ZX12R
getusome
smokin
posted October 03, 2007 05:00 AM
where are the flies located at .?
CJ
87gtNOS
posted October 03, 2007 05:08 AM
Your throttle bodys have secondary butterflies, that are useless! Do a search on here, try searching 'flies removal' very simple procedure!
01 ZX12R
getusome
smokin
posted October 03, 2007 05:25 AM
Just got this one . cannot get all of the info on the bike.
CJ
ZXLNT
posted October 03, 2007 08:39 AM
Again, Huh??
jdzx14
posted October 03, 2007 08:43 AM
Use the search thingie! At top of page.. trust me it works.
2007 Black ZX-14
getusome
smokin
posted October 03, 2007 10:29 AM
got it sorted out . time for a new back tire
CJ
bryan76
posted October 04, 2007 01:54 AM
does the bike run lean with the tre006 or do you have to buy a power commander and remap it
87gtNOS
posted October 04, 2007 02:58 AM
Bryan, if you are buying a TEE006a, you obviously have no flies....so yes, you need a PC. Well, call Ivan as I am not sure, maybe if you are all stock, you won't need the PC.....
The TRE008 is for if you have flies still, and no PC is required.
01 ZX12R
tater
Shakin off the Haters
posted October 04, 2007 11:48 AM        Edited By: tater on 4 Oct 2007 12:50
so what is a Tee006 and Tre008? I have a power comander with the two bros carbonfiber pipes, and when i let off the throttle its backfires a lil bit. So if i take out the buterflies, will it stop backfire? and where do i get one of these Tee006?
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
87gtNOS
posted October 04, 2007 11:50 AM
pull the flies, get the TRE006a (for no flies, TRE008 for flies) and leave mapping the way it is. Backfire will be gone almost completely. The bike will also be smoother at low rpms.
Ivan's performance sells the TRE device.
01 ZX12R
tater
posted October 04, 2007 11:56 AM
thanks 87, will get to this soon.
ZX-14 06
Flies out
-1 front, +2 rear
Tiger tail
64inch wheel base
lowering links
0.24105787277222 seconds processing time
