BIKELAND > FORUMS > ZX-14.com > Thread: Mirrors NEW TOPIC NEW POLL POST REPLY
riaansh
posted September 17, 2007 10:02 AM
Mirrors
I scratched my one mirror and would like to spray paint it. How do you take the plastic part behind the mirror off? I did take the screw out inside the plastic shell but it is still stuck to the mirror.
Thanks Riaan
FasterThanStink
posted September 17, 2007 10:03 AM
Can't you just mask it and paint it?
That's what gets you.
riaansh
posted September 17, 2007 10:17 AM
Are you sure? There is a screw inside that I took out. Does it clip in and will it brake when you take it apart?
ZXLNT
posted September 17, 2007 04:01 PM
Are you talking about removing the mirror from the housing? If they are made like the ZX12R mirrors, the mirror portion has a ball on it that pops into a socket in the main mirror housing. Pull out straight and hard.
riaansh
posted September 18, 2007 09:54 AM        Edited By: riaansh on 18 Sep 2007 10:56
Sorry only saw your threat now. Yes I would like to separate the mirror from the housing.
As mentioned before, there is a screw inside the housing, but you have to push the screwdriver through the opening to get hold of the screw. When you look closely you do see a ball in the housing. I wonder if it's not the same then as a zx 12's mirrors. Does a zx 12 and the 14's mirrors look the same? Tried to separate it but was to scared to brake the housing.
0.32687020301819 seconds processing time
