BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 Fully Adjustable Lowering Links NEW TOPIC NEW POLL POST REPLY
Brock
Sponsor
posted September 12, 2007 10:32 AM
http://shop.brocksperformance.com/Detail.bok?no=945
Set of 3 Hole Fully Adjustable Lowering Links
for the ZX14
  • Position #1 - Stock
  • Position #2 - Middle Position
  • Position #3 - Slammed
  • Quick release pins allow for fast changes while
    fine adjusters let your bike
    be lowered in small increments.
    http://www.BrocksPerformance.com
    Brock's Performance Products
    1956 Woodman Centre Dr.
    Dayton, OH 45420
    Ph.(937) 298-6818
      Ignore this member    Click here to visit Brock's homepage.
    billeason
    posted September 12, 2007 03:01 PM
    Hi brock, will these fit the macintosh arm. I bought one from you and had it chromed. WORK of art, but my adj links wont fit they hit the under bracing. In other words i cant turn them. The links are spencer cycles,and are thick but very good qauilty. I had to put my three hole lower links back on. Kind'a defeats the purpose of the arm if i cant get it any lower. IF you could let me know if these or if you know of another set of adj.lower links that will clear this arm, would be a big help. Thanks, ....bill at Cannon Cycles...
    bill eason
    Brock
    Sponsor
    posted September 13, 2007 05:38 AM
    Bill,
    It depends on the year of the Macintosh arm. New arms were designed with extra clearance so they can be used with the Fully Adjustable Lowering Links (ZX14-ALLS). Since yours is 2007, you should not have any problems. Older swingarms should also fit, but the clearance will be a bit tighter.
    billeason
    posted September 13, 2007 10:45 AM        Edited By: billeason on 13 Sep 2007 11:51
    Thanks brock, as usual customer service second to none. I will contact jim tomorrow. Care to give a little preveiw of 08-14? LOL. All kidding aside whats the time line on alien head for the 14, i have four customers ask about them in the last two weeks.Thanks, bill
    bill eason
    Brock
    Sponsor
    posted September 14, 2007 05:47 AM
    Bill,
    I misread your post!
    If the Spencer's will not fit...our new links will not either- sorry for the confusion!
    We are working on another fully adjustable design since McIntosh does not make his any longer.
    Get with me an a couple of weeks via e-mail and i will tell you about the progress.
    Brock
    billeason
    posted September 14, 2007 06:45 PM        Edited By: billeason on 14 Sep 2007 19:46
    I thought that's what you meant any way. I 'll wait until you get the new ones finished, terry had told me he did not make them any more. I got two alien's coming, ones for a big motor 14. Stroked / bored balanced, we are running it on dyno now with smeg. when the ex gets here thats all we are going to change at first. then we'll map it for alien. We are all like kids in a candy store round here trying to decide who's 14'sgoing to get what ex to test. Its a tough job sometimes, LOL. ... Bill at Cannon...
    bill eason
    Seth ZX12r UK
    posted September 17, 2007 05:26 AM
    Will these fit the ZX12?
    Could they be adapted/drilled to fit a 12r?
      Ignore this member    Click here to visit Seth ZX12r UK's homepage.
    Brock
    Sponsor
    posted September 17, 2007 10:01 PM
    Bill,
    After digging deeper......
    If you lay a straight edge from the pivot point where the links mount- some arms have at least 1" clearance to the lower hoop brace...some do not. Our links require @.625 clearance. If you have more than this, ours will fit.
    Brock
    Brock's Performance
    billeason
    posted September 18, 2007 08:52 AM
    Brock you must be reading my mind, i measured the clearance over the week end. I was going to post that very question to you to see what clearance your links need. At @ .625 i have just shy of .125ths more for a total of .750 , close but they will work. I got an order for some ex,systems to make i will try a set of links. Thanks brock. bill at cannon...
    bill eason
    Seth ZX12r UK
    posted September 18, 2007 08:56 AM
    with those clearances will these fit a 12r?
    0.21071910858154 seconds processing time
