BIKELAND > FORUMS > ZX-14.com > Thread: My ATP stage 2 turbo is done NEW TOPIC NEW POLL POST REPLY
iflyems
posted September 11, 2007 08:44 AM
As most of you know, I spun a rod bearing in my ATP turbo equipped ZX14 about 4 months ago. I shipped the bike off to ATP and had them to a complete redo on the motor. The cost was $xxxx, more than I want to say, but its finally finished.
I'll be having the bike shipped back to me in about a week or two, then off to the track, before winter sets in.
My goals are to just duplicate what I've already done E.T. wise, but to hit at least 175mph. Problem with E.T. will be limited traction at the track I'll be going to (KCIR), and a short shutdown area. So I'm gonna ease into it. I don't wanna run out of track.
If the weather holds, and I have the time off, I'll then go to Heartland-Topeka, which has a much longer shutdown area, and run the piss out of it.
Next year I'll be getting a TIC 1000 programmable boost controller to help with the launch, etc. But right now money is tight, so it will have to wait.
The numbers are around 403hp and around 200ft/lbs of torque. We're not going to dyno it because that just puts added stress on the motor that won't be needed. There is already another stage II ATP turbo ZX14 out there, and thats what he's putting out with around 22psi of boost, so we'll use that map, and boost level. I will turn it down of course, and ease into it. Might not even use nearly that much boost until I get the boost controller and re-learn how to ride/race the bike, again.
The pictures are of the waste gate. If you look closely you can also see the Adams Performance billet oil pan, purchased through Orient Express.
tater
Shakin off the Haters
posted September 11, 2007 01:48 PM
what all did ATP do to the motor to be able to handle 22lbs of Boost? what type of pistons, cams and head work?
jdzx14
posted September 11, 2007 02:42 PM
I am speechless. Congrats on having a badass bike! Please make a vid!!!
2007 Black ZX-14
cool
posted September 11, 2007 04:45 PM
Even you turn it down i would still use dyno to keep good air ratio.unless using.race gas if not tune will burn up pistons.you can burn up built motor with only 6 pounds.im at 300hp with 190ft torque with 15 pounds.
iflyems
posted September 12, 2007 05:40 AM
We used JE turbo pistons, carillo I-beam rods, titanium valve springs, stronger engine studs, stock cams, race cut transmission.....and I know I'm forgetting something.
tater
posted September 12, 2007 07:53 AM
thats a good bit of expensive goodies. Weel good luck with it. Hope to see some time slip's up on it soon.
tg1820
posted September 12, 2007 08:25 PM
Looks good!
iflyems
posted September 13, 2007 08:49 AM
Thanks. Its on the truck as we speak. Should arrive next week. Thinking about going to the track next Friday.
Stage XXX Mr Turbo ZX14
posted September 18, 2007 08:58 PM
Looks real nice .. . . .. . I bet you can't wait to get that bad dog to the track you will have to let us know what you run
iflyems
posted September 19, 2007 07:10 AM
Will do....it arrives from California in about an hour. Just talked to the truck driver and he's almost here. Will put it into the garage and clean it up and make a few adjustments, then going to KCIR on Friday.
Not sure if it will post big numbers as the track has a real short shutdown area, and I had enough problems stopping it at 168mph last time, at a different track.
Hoping to get somebody there to video me.....might take a friend along. I really don't know what it will run this time. They do nothing to prep the track at KCIR.....only sweep it...no VHT or trackbite....so I predict a quarter mile burnout.
blackbullet76
posted September 19, 2007 10:21 AM        Edited By: blackbullet76 on 19 Sep 2007 11:22
If those hp & torque numbers are correct, you're puttin out more power than the pro stock bikes that are on tv. Maybe you should get a big ass slick for the back of it
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
dutchzx14
posted September 19, 2007 10:30 AM
I'm really jealous.. thats what I like what u done with your bike....!! don't you gonna try it out on the street?? I'm going to look out for the numbers (hp) when u post them ..
  Ignore this member    Click here to visit dutchzx14's homepage.
posted September 19, 2007 10:34 AM
Ifly
ok its been an hour already .. where is the times ? lol
XXX
TG1820
posted September 19, 2007 11:09 AM
You don't really need the pressure of being taped the first time out. Go out and be careful get feel for it then tape a copy for us! Post some pictures when you get unpacked!
I am going after mine as soon as the repairs are made to the motorhome.
iflyems
posted September 19, 2007 04:23 PM
Mines in the garage now. Just got finished cleaning it up. Gonna have to put the 43 tooth rear sprocket on it as there is too much slack in the chain at 17/41, and I'm out of room on the brake slider to go back any further. Eventually I'll go with an 18 tooth front sprocket, but am fresh out right now, and I'm going to the track on Friday.
The bike starts right up and runs flawlessly. I drove it on the street for just a minute or so, didn't even boost it, it just as smooth as it ever was.
BTW, I have the boost set at around 10psi or so.......probably won't crank it up for awhile. Besides, not many tracks will hold 400hp all at once. I really think we're going to need a boost controller to use all that we have. I also think anything more than 400hp is a waste, and really pretty much unusuable in the current frame, and with a street tire. For top speed runs thought, it would be ideal.
Also, the billet oil pan I got is more than I could ever have imagined. It truly is beautiful, and you can hardly see it on the bike. The nice thing is now, my ground clearance is limited to the lower black plastic fairing......so I could pretty much slam the bike if I wanted. Its amazing how much ground clearance you gain with the pan.
posted September 19, 2007 04:42 PM
ifly,
good to hear that everything is great, i bet it is a big relief to have it back. you are right on the money when you say how that pan gives you a ton more ground clearance. we had to reconfigure a few things to get the max drop but yet maintain the right ground clearance for prostar rules. A few of the mods were the front forks, lower belly wing, lowering links werent low enough, so we had to use the adjustables, rear shock mount , etc. But at the end of the day those little things just might give you the edge. so you are not using a boost controller? how about a boost guage? if so were are you mounting yours?
if i knew how to paste a picture i have a real nice shot of the pan on my bike, i had mine polished and anodized black chrome. i will have to figure out how to do that.
XXX
iflyems
posted September 19, 2007 07:15 PM
I have a boost guage and fuel pressure guage mounted to the top of the triple tree. Don't have a boost controller yet, but I do see one in my future.
MADKAWZX14
RUNNING OUTTA CASH FAST
posted September 19, 2007 11:15 PM
Very cool!!
07 ZX14 CUSTOM PAINTED, BMC RACE FILTER, MUZZY M10, NITROUS, SPEEDOHEALER, FLIES OUT, MUZZY STROKER w/ GOODIES, PCIII w/CUSTOM MAP, ETC....
sj1400
posted September 20, 2007 03:52 AM        Edited By: sj1400 on 20 Sep 2007 04:53
iflyems - is there any room for a intercooler or water injection ? Are you using pump gas or race gas ? When I got my 1st turbo Busa in 01(Hahn) I melted the pistons doing top end blasts on pump gas.
Nice set up you have...
iflyems
posted September 20, 2007 04:44 AM
No room for an intercooler. Don't know about water injection. Im running VP C16 race gas, and have the timing retarded about 6 degrees.
ZXLNT
posted September 20, 2007 04:49 AM
Not the first Hahn kit I have seen burn pistons. Either you were lean or the turbo was boost creeping which is a fairly common problem with the Hahn kits...
iflyems
posted September 20, 2007 08:19 AM
The kit that Dave sells for the ZX14 is an ATP kit. Dave=Dave Hahn of Orient express. He knows his stuff when it comes to turbo's. They already have an ATP turbo'd ZX14 running low 8's, stay tuned as we both work out the bugs.
posted September 20, 2007 06:47 PM
ifly,
Did you ride your bike today? how is it? Start? Run? feel? on the street You mention working out a few bugs, what are they?
XXX
iflyems
posted September 21, 2007 05:03 AM
I rode it around the block. Started immediately and purred like a kitten. Ran very smooth. I will be running it at our local track tonight, but don't expect any big numbers; I've got the boost at around 10psi, and the track has poor traction at best, and a short shutdown. I just wanna shake down the bike, and take it easy on the new motor, but we'll see. Last time I said I wanted to take it easy I went 8,80 at 168 on about the same boost, spinning the tire. so who knows.
posted September 21, 2007 10:41 AM
ifly ,
I wish you good luck, and take it easy for the first few passes,
XXX
0.28457808494568 seconds processing time
