blackbullet76
posted September 08, 2007 07:04 AM
Stretched on the street
Man, I didn't realize how easily the back tire would spin on the street after stretching my 14. I aint gonna be able to go to the track tonight to test it out because I gotta work, but on the street all I do is spin in the first 2 gears and on certain pavement it breaks loose in 3rd. It's kinda fun, but I'd like to feel it bite so I can get used to it before I race it. Guess I'll have to wait.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
mark524
posted September 08, 2007 07:57 AM
how much air is in your tire? I run 11 psi with the tire cold (shinko usoft) and it will still spin on the street a little. but it hooks at the track
posted September 08, 2007 08:00 AM
I've watched a bikeland member fishtail all over the place through the gears while riding his stretched 14 on the street every time we took off from a stop, was awesome!
blackbullet76
posted September 08, 2007 08:20 AM
quote: how much air is in your tire?
I'm running the regular 40 psi on the street.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
smokinzx14
posted September 08, 2007 09:35 AM
quote: I've watched a bikeland member fishtail all over the place through the gears while riding his stretched 14 on the street every time we took off from a stop, was awesome!
Now Steve what bikeland member would do that .....?
mark524
posted September 08, 2007 10:12 AM
you'll never hook with 40 psi. you'll probably have to go down to around 15 psi maybe lower. depends what tire you have.
Tool Man
posted September 08, 2007 10:24 AM
A lawless one ... :d
The banks are failing..
The banks are failing...
Invest in Ammo
posted September 08, 2007 10:49 AM
uhmmm I'll NEVER tell
johnsonzx14
posted September 08, 2007 11:14 AM
Im about to put my swingarm on, mine is 4 over....Im sure Ill have the same problems...
blackbullet76
posted September 08, 2007 12:50 PM
I'm at 6 1/2 over. Should be close to 7 when the new chain stretches. You might be ok at 4 over.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
johnsonzx14
posted September 08, 2007 08:26 PM
ever get your damn oil pan?? I am getting mine back tomorrow.... I just had my stock one modified...
lietoome
posted September 08, 2007 08:54 PM
are you stretched fellas lowered too?
My biggest problem is braking hard. Yes, I use the rear brake.(very short track after the traps!) Back tire locks up really easy when on the brakes hard. Just keep that in mind if you are stretching.
I'm 9" over and LOVE IT!
posted September 08, 2007 09:14 PM
Edited By: stevewfl on 8 Sep 2007 22:15
Put a pilot power on the front rim and you won't have to worry about the back brakes!
lietoome
posted September 09, 2007 06:48 AM
steve, I got one on the front already. I like using my front and rear brakes. I warped the front rotors on my 12 at this same track. I'm trying to avoid that...not to mention, I think its real important to know just how much brake(front and rear) I can give this monster before it starts sliding.
BTW steve, I thin you skinny guys can stop a lot quicker than me
johnsonzx14
posted September 09, 2007 07:21 AM
Yeah, mine is lowered 1 1/2 inches in the front and about 2 and a 1/2 in the back, it will go lower as soon as I get the arm on, and the new oil pan... Then Im going to get the forks cut, so I dont have to worry about slammin my front fender at the track....
lietoome
posted September 09, 2007 02:57 PM
are you gonna ride it that low on the street?
serius blk
posted September 09, 2007 04:08 PM
i have a pilot power on the back of mine. Im only 4in over and 16/43. My pilot spins like crazy. I may low the air pressure since its at 38psi.
