BIKELAND > FORUMS > ZX-14.com > Thread: VP fuels MS103 in place of MRX01 NEW TOPIC NEW POLL POST REPLY
mark524
posted September 08, 2007 06:35 AM
Has anyone tried MS103 instead of MRX01? Just wondering what the difference is. I can get it locally but can't get MRX01.
Here's the description from VP
MOTORSPORT 103
MS103 provides power and protection equal to some leaded racing fuels. Compared to Motorsport 101, it allows even more aggressive timing and higher compression-up to 14:1 in cast iron head engines and up to 15:1 with aluminum heads. Can allow doubling of stock boost - consult your engine builder. Also contains no metal compounds and won't harm catalytic converters or oxygen sensors. AMA legal for Supercross & Outdoor Nationals.
• Color: Red
• Motor Octane: 99
• R+M/2: 103
• Oxygenated: Yes
• Specific Gravity: .743 at 60° F
flatoutbu
posted September 08, 2007 07:17 AM
are you going to be running higher compression?...if not, your not going to need the MS103....you'll make more power of pump gas. The basic fuels your going to see guys use are..pump gas....U4....MR9.... and MRX10. The MR9 is going to give you the biggest hp gains from just pouring it in but it's going to be the most expensive. I know the U4 and MR9 are oxgenated..i'm not sure about the MRX10 because i never used it.
06 Blue 14
9.008 at 153mph @ 195 suited
mark524
posted September 08, 2007 07:54 AM
sorry, forgot to say I want to spray with it
flatoutbu
posted September 08, 2007 08:04 AM
then the MRX10 should work good for ya...
06 Blue 14
mark524
posted September 08, 2007 08:07 AM
don't you think the ms103 is pretty much the same? I can't get mrx01 with out driving a few hours to get it. They have the ms103 right here in town. I had never heard of anyone running it, but they seem very similar. might be cheaper too.
flatoutbu
posted September 08, 2007 08:23 AM
i never used it so i can't be a 100%.....I know/seen/heard from alot of guys running the MRX10...that's what they use for a bike with high compression and nitrous. I think try out the ms103 and see what happens.....when you just dumping gas in the bike, your kinda down to splitting hairs...unless your bike needs or is tuned for a specific gas...I know it cost 25 dollars to have u4 shipped to my door.
06 Blue 14
mark524
posted September 08, 2007 08:29 AM
where do you order the u4 that will deliver?
Nukedog
posted September 10, 2007 05:43 AM        Edited By: Nukedog on 10 Sep 2007 06:44
It's NOT MRX10 it IS MRX01 there is also MR9 and MR10.
02 Busa...Turbo...
09 YZF-R6S...
posted September 10, 2007 07:06 AM
Send an email to VP, asking what the difference is...
http://www.vpracingfuels.com/index2.html?mgiToken=0C15B7C83474A4E929
mrx01 is perfect for 12's, 14's, Busas with motorwork...
If you want to spray then just use 92 octane pump gas, waste of $$$ to use VP race fuel with spray in non Pro Racing...
0.22385716438293 seconds processing time
