BIKELAND > FORUMS > ZX-14.com > Thread: 2.5 lb nos bottle fit under a Catalyst seat? NEW TOPIC NEW POLL POST REPLY
mark524
posted September 02, 2007 05:47 PM
Anybody have a 2.5lb nitrous bottle under their Catalyst seat?
posted September 02, 2007 10:47 PM
UNDER THE SEAT!? dude have you looked at the available space under there
mark524
posted September 02, 2007 11:42 PM
catalyst seat has a huge area behind where you sit. They advertise that a 2 lb. fits, but I was wondering if a 2.5 lb would. It's the same diameter but 1 1/4 inch longer.
Bently
2012 14r In Blue and no Mods!
posted September 03, 2007 05:12 AM
Yes I had my 2.5 pound bottle under the catalyst seat
kawpower
Mr kawasaki 2 you!
posted September 03, 2007 05:36 AM
Fits perfectly
mark524
posted September 03, 2007 05:55 AM
cool. Which way did you angle the valve? If the valve is down you have to take the siphon tube out right?
posted September 03, 2007 06:23 AM
i just didn't realize the bottle was that small
mark524
posted September 03, 2007 06:28 AM
also, Did you use a bottle bracket to mount it to the bike? Or did you just lay it in there?
Bently
posted September 03, 2007 10:55 AM
I went the cheap way and used a bunge strap around the bottle and to the frame.
billeason
posted September 03, 2007 11:58 AM
Angle the valve towards the back of bike, it will lay almost at the preferred angle buy its self. I used the tube in mine, the hit is soft but the torque curve/hp is so flat the bike is easy to ride. With 30 jet iam getting an actual 20 hp. Iam also using the dyno tune bottle bracket with the two holes drilled thru plastic fender,an large flat washers on under side. Works fine an cheap. bill at cannon cycles...
bill eason
87gtNOS
posted September 04, 2007 10:33 AM
Pics please!!
01 ZX12R
Halvefast
posted September 10, 2007 07:51 AM        Edited By: Halvefast on 10 Sep 2007 08:52
Has anyone mounted it valve down under the seat?
I don't have a siphon tube in my bottle, would love to hide it,
instead of mounting it on the swingarm.
How much of an angle is needeed when mounted valve side down?
0.26780700683594 seconds processing time
