BIKELAND > FORUMS > ZX-14.com > Thread: Stalling when I clutch at high RPM NEW TOPIC NEW POLL POST REPLY
phytrax
posted September 03, 2007 03:18 AM
Ok, I started having this problem a few weeks ago. When I run the bike up to around 8-10k rpm and then grab the clutch and coast, it stalls sometimes. It was doing it a lot. I talked to a mechanic said I was running too lean. I had leaned out the low rpm range on my PC3 to save a bit of gas and maybe get some extra hp at the same time. It had begun to stall a lot, so I reverted to Brock's street map. The problem completely disappeared for 500mi or so. I noticed a few decel pops yesterday, then it stalled 2 times on me over 300 miles or so. Anybody know what's going on? It was pretty hot yesterday so I don't see why it would run lean unless the temperature sensor is overcorrecting. If I need to make it richer, which part of the map do I need to richen for this specific problem?
KX450F - kickstand
>>> MySpace --CLICK-- <<<
Bently
2012 14r In Blue and no Mods!
posted September 03, 2007 05:29 AM
I would check your Idle, mine did the same thing until I raised my idle about 200 to 300 rpms. then everything was fine.
smokinzx14
posted September 03, 2007 08:23 AM
+1 and also check your TP setting in your P/C ...
posted September 03, 2007 02:15 PM
Why would you be cruising up around 10,000rpm and pull the clutch in anyway???
Good way to cause unessessary wear on the engine and clutch!!!
Just my
phytrax
posted September 04, 2007 06:40 AM        Edited By: phytrax on 4 Sep 2007 07:41
I don't "cruise" up to 10,000 RPM really. When I pull off from red light, stop sign, etc, I usually accelerate up to speed in 1st then coast while I shift up to 5th or so. I do similar if I'm passing. Usually it's more like 8,000 rpm.
I'm not sure it's a idle problem as it's only an issue when I clutch like this, it never stalls otherwise. Like I said, remapping helped a LOT the first time I did it. Yesterday I was noticing decel pops a lot more than usual, which also leads me to believe it's a lean condition.
What is the TP setting? Throttle percent? I've done that already.
KX450F - kickstand
0.21349692344666 seconds processing time
