BIKELAND > FORUMS > ZX-14.com > Thread: what 60ft to shoot for? NEW TOPIC NEW POLL POST REPLY
blackbullet76
posted September 01, 2007 09:03 AM
I'm going to install the extensions and bigger rear sprocket tomorrow. I'll probably put it at 64 inches (7 inch stretch) with 16/44 gears. What 60 foot would be good for this setup? I'll be running a stock bridgestone.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Bently
2012 14r In Blue and no Mods!
posted September 01, 2007 09:21 AM
Think your going to have problems with the stock tire unless your track is preped really really good. I was only 4.5 over and had trouble on a marginal track with an ultra soft shinko. I was down to 10 psi a few nights. stock tires work well for stock wheelbase only imo. you better spend the extra 110 and put a shinko on it. I had a 1.44 best at 4.5 over.
blackbullet76
posted September 01, 2007 09:36 AM
I might do that, but for now I'm gonna try what I've got. The track is usually prepped good.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
kawasaki_rick
posted September 01, 2007 11:35 AM
Waste of your time going 2 the track with a stock tire and extensions. Itl smoke it. Get a tire.
BlackMagic14
posted September 01, 2007 12:09 PM
I agree IT WILL NEVER HOOK!!! low 1.50s is a good point to shoot for but for the really good e.t's eventually you need to be in the LOW 1.40's high 1.30's
blackbullet76
posted September 01, 2007 12:10 PM
Well, I might wait until the bridgestone is wore out then before I put on the extensions.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
kc jr 54
Fat Guy
posted September 01, 2007 12:50 PM
Traction issues are going to haunt you even with the Shinko. Unless you are really really good, i say mid 1.4's will be what you should aim for at first. Once you get the hang of the combo and arent spinning terribly, i think a 1.38-9 would be your best goal. IMHO
blackbullet76
posted September 01, 2007 02:10 PM
Thanks guys. I might just roast the bridgestone tonight at the track and get a shinko next week.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
Nukedog
posted September 01, 2007 02:53 PM
If your shock is set right you will hook. Shinko U-Soft and you will be fine.
1.46 should be close to where you will be based on your weight...
02 Busa...Turbo...
09 YZF-R6S...
smokinzx14
posted September 01, 2007 08:15 PM
Yup you are going to need a Shinko or some other type of sticky tire ....I think you will be able to hit mid 1.40s maybe even better ...BUT it will take some seat time to get there ....Don't give up if it doesn't come real fast , you have to keep working on it and it will come in time ....Hey don't sweat it just go have fun ...Smokin..
blackbullet76
posted September 02, 2007 02:08 PM
Here it is. I just finished it. It's pulls pretty hard now with the 16/44 gearing. It spun on the street when I hit 3rd. I might need that shinko
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
blackbullet76
posted September 02, 2007 02:09 PM
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
smokinzx14
posted September 02, 2007 04:10 PM
Hate to tell you this , it will not hook on the street no matter what tire you use ...Even a slick will spin on the street ....But the shinko will work on the track ...
blackbullet76
posted September 03, 2007 04:22 AM
Oh ok. I just thought since it spun on the street that it might do it on the track. What number shinko do I need for the track? I've seen 003, 005 and 008.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
Bently
posted September 03, 2007 05:09 AM
ultra soft i would say
blackbullet76
posted September 03, 2007 05:36 AM
So, 003 ultra soft? I seen an 008 slick on ebay. Would that be better or is that for road racing?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
mark524
posted September 03, 2007 06:01 AM
get the 003 ultra soft. Make the the tire say "u-soft" on the sidewall. I went with the regular 003, and when I extended, I was spinning and I'm 290 lbs. Put on the usoft and I'm not spinning anymore. I run mine about 11 psi cold to hook at the track.
blackbullet76
posted September 03, 2007 07:21 AM
thanks mark
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
0.23784208297729 seconds processing time
