BIKELAND > FORUMS > ZX-14.com > Thread: Does anybody have,M4 Retro Drag Slip ons NEW TOPIC NEW POLL POST REPLY
MGrizz
posted August 08, 2007 04:18 PM
I was wondering if anybody has, M4 Retro Drag Slip On's . Pictures and coments on the sound etc. Thanks !!!
jdzx14
posted August 08, 2007 04:32 PM
I dont but I have a buddie with a special edition 14 that is about to order a set, I will let you know how they sound! Might be a week or so. I am pretty sure there is someone who has them on here, I remember a thread where a guy recommended them.
Smurfslayer
posted August 13, 2007 09:46 AM
yes
I have them on my 06 14 for a few weeks now. They're way louder than stock, and a bit louder than my very modded ZX11 w/ Micron exh. The sound is a deep sound, not a "tinny" or low quality sound.
They are much lighter than stock, obviously, and I'm sure they're less restrictive. I have the flies out + PC3, using the stock exh. & no flies map. The only available M4 map was significantly leaner than stock below 7k, so I've left the stock/no flies map in. It runs fine and is probably a little fat below 7k. Above 7k there's very little difference in the maps, I compared this one and the M4 slipons map ( for a bike with the flies installed ).
Aesthetically, they have a great "look" and their finish is very good. I got mine used and the deal was too good to pass up.
The only thing I dislike about them: Fit.
The install took just over an hour. Basically, the LH exhaust pipe does not have a long enough relief to fit fully on to the stock header. It will install to a point of "close enough" leaving about 3/4" between the mount hole & pipe hanger. I was eventually able to cajole it into place.
HTH
Dave
www.usrkba.org
  Ignore this member    Click here to visit Smurfslayer's homepage.
jdzx14
posted August 13, 2007 10:57 AM
HTH
Man can you please post pics!! I have a buddy wanting these pipes on his 07 but he cant find any pics! Thanks,
Smurfslayer
posted August 13, 2007 03:50 PM
pics
Got pics of the M4's at
http://www.bighammer.net/zx14.html
Scroll to the bottom, they're thumbnails and open to larger images.
Since I don't clean exhausts, this is the cleanest anyone will ever see them again... Even so, you can see they look pretty sharp and don't "show" much road grime, etc.
Dave
www.usrkba.org
TWISTED326
Traffic Violator
posted November 15, 2007 09:46 PM
HTH
What's the latest info on a map? I've got an '07 with PCIII and M4s on the way soon.
I was thinking of using the Muzzy slip-ons and flies out map. You try this yet?
Bently
2012 14r In Blue and no Mods!
posted November 16, 2007 03:13 AM
I've seen them in pictures and as far as slip ons go I think they look very good!
qwick
posted November 16, 2007 05:40 AM
Check with Brock... He may have an Alien Head dual slip-on system in the works.
Smurfslayer
posted November 16, 2007 05:51 AM
"What's the latest info on a map? I've got an '07 with PCIII and M4s on the way soon.
I was thinking of using the Muzzy slip-ons and flies out map. You try this yet?"
I picked up another map from a forum user at zx14ninja.com and installed it on my 14. I can only say tentatively that the map works much better than the stock / no flies map down low. it was for a 14 w/ no flies & Yosh slip ons. I haven't had it on in the heat yet but so far so good. I did a map compare and it's slightly leaner up top, and underneath the flies opening it's pretty close to stock.
Dave
www.usrkba.org
slates
posted November 16, 2007 10:07 AM
I asked Brock about these not too long ago and here was his response:
"We should have them in stock soon. If maps are needed. We will provide them at no charge. We are still in the test stages. We will also have smegs and new short megs."
Bd
Sent with Wireless Sync from Brocks Verizon Wireless cell
I'm sure he'll post when either of these are ready...he's defintely got his hands full right now.
0.22604393959045 seconds processing time
