BIKELAND > FORUMS > ZX-14.com > Thread: Should You Breakin with Stock or Aftermarket Exhaust? NEW TOPIC NEW POLL POST REPLY
biggcoolg
posted August 01, 2007 04:24 AM
I would like to know if you can put an aftermarket exhaust on a brand new ZX-14 out the showroom or should you break it in first with the stock exhaust? I've heard different things regarding this. Thanks.
dutchzx14
posted August 01, 2007 04:27 AM
I would say stay bone stock for the engine exhaust back presure.
  Ignore this member    Click here to visit dutchzx14's homepage.
TJ
posted August 01, 2007 05:02 AM
It doesn't matter.
Pat Dietrich
posted August 01, 2007 07:45 AM
I waited till 125 miles only because my pipe was on back order. Should not make any difference at all.
LeoVinceZX14
Thankfully...its paid for...
posted August 01, 2007 10:08 AM
Rolled out the showroom with mine...
Bigcoolg:
I rolled out the showroom with mine installed (3 miles on the ODO when I got it). The bike hasn't had any issues. Probably the biggest reason I'd say do it from day 1 is the bike will run cooler (you ditch the cats in the mufflers) which drops the radiant heat and the operating temps. Side benefit is you also will drop 15-20 lbs depending on what pipe you run. Did I mention it will sound...way better.
Ride safe.....
'12 14R SE
PC V
Custom map
BMC filter
Leo Vince 4-2-1 w/ carbon can
Sato frame sliders
Supersprox 42T
Cox radiator guard
DID 530 X-ring chain.
biggcoolg
posted August 01, 2007 04:31 PM
Thanks Everyone for the advice.
posted August 01, 2007 05:33 PM
It doesn't matter.
+1
KUTT 14
posted August 02, 2007 07:19 AM
i ordered mine with a Tsukigi system and it was shipped to me with 65 miles on the odometer all from dyno break-in at the dealer and no problems
KUT
0.24130797386169 seconds processing time
