BIKELAND > FORUMS > ZX-14.com > Thread: ZX-14 newbie questions NEW TOPIC NEW POLL POST REPLY
Biggy_P
posted July 31, 2007 10:25 PM        Edited By: Biggy_P on 31 Jul 2007 23:47
Just bought an '06 ZX-14 (stone stock) and doesn't seem to have the 175hp that I read about everywhere. I was expecting my arms to be torn out trying to tame the beast.
Questions:
1. What are "flies" and what benefit does removing them have?
2. Would a PCIII help the throttle response?
3. What are the best mods for the buck?
Thanks in advance
After a little searching I found the answers:
A PC and removing the "flies" will do what I want it to do and it is relativity cheap.
'06 ZX-14
Stone Stock
'03 Aprilia Tuono
Buttload of fun parts
posted August 01, 2007 03:29 PM
there is a plethora of info on each topic you questioned. I suggest using the search feature to search these threads, or google
posted August 01, 2007 04:37 PM
Wow, there goes a $ 20 word
smokinzx14
posted August 01, 2007 04:37 PM        Edited By: smokinzx14 on 1 Aug 2007 17:38
175 where did you get that number for stock?? cycleworld magazine ?? stone stock brand new low miles it's 162 163 hp.. after break in 169 hp.. ....Mine ran great with the flys in place with just a p/c and pipe .. 9.18 @ 152 it seemed to have arm ripping power to me ..
BIGZXDADDY
posted August 01, 2007 05:23 PM
i've heard the 175 horse thing too but when dyno is on the floor how to duplicate ram-air effect at 150 mph+? did the factory or some other tester cram air in front at high speed to come up with that # ? IMO the 175hp is possile under right circumstances. i'm judging that from personal experiments with dyno and mostly stock automobiles. ambient air temp and pre-induction air velocity can greatly change the numbers. most of that shit doesn't play in the real world though where conditions are seldom optimal
"never drive faster than you can see, besides it's all in the reflexes"
posted August 01, 2007 05:30 PM
I bidded the word out at 19.91 and received a best proposal back at $21.07.
Using formula P+0 over 2, your 20 bux short-changed me by .49 wtf
phytrax
posted August 02, 2007 12:08 AM
Here's a quick answer Biggy, flies restrict the low end of the bike to prevent novice riders from killing themselves with the arm ripping power. It's a lot more violent if you remove them. You need to install a PCIII with the right maps if you do this. Add an aftermarket exhaust too, and you'll have all the arm ripping power you could want. Flies and PCIII are easily the best bang for the buck. Exhaust next.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
V2K_CCTX
posted August 02, 2007 11:02 AM
THE THEORY
In essence, the theory behind forced-induction systems like Kawasaki's is quite simple and not that far removed from turbocharging, just at a less extreme level. A motorcycle traveling at high speed is pushing a slug of pressurized air ahead of it. If an air inlet is placed in the correct place, then air entering the airbox will be at greater than atmospheric pressure. The resulting intake charge will be denser and cooler and contain more oxygen and fuel, thus causing a bigger bang and hence-Hallelujah!-more power.
There are limitations. The amount of mixture you can force through a motor is finite. Imagine strapping a ZX-9R on top of a jet aircraft and starting the motor; the plane will rapidly reach a velocity where the motor would be incapable of utilizing the volume of mixture being forced into it. Next, at very high speeds-over say 150 mph, where theory says that ram air should be working most effectively-the nature of air drag means that large increases in horsepower are needed to produce relatively small increases in speed. Finally, compared to a turbocharging system, the increases in pressure are quite low. How low? Before we began testing, Burns predicted, "I don't think we can get more than one psi in there."
THE ZX-9R SYSTEM
Kawasaki's ZX-9R uses a relatively straightforward system compared to the 1995 Honda CBR600F3. Twin vents mounted beneath the headlight channel air via ducts running over the frame beams and into a sealed airbox. Look closely, and you can see two smaller nozzles behind the grilles which connect to the carburetor float bowls. Their function is to equalize the pressure between float bowls and airbox; without them the higher pressure of the incoming charge would upset the carburetion, potentially blowing fuel out of the bowls and tending to push fuel back down the jets, causing mixture leanness. Kawasaki uses much the same system in all its ram-air machines, though the ZX-7 and earlier ZX-11s have a single inlet only.
MEASURING
To reproduce the effects of high-speed running on a static dyno, Burns' intention was to use a fan capable of producing relatively small volumes of air, but at high pressure. The fan was connected via custom-made tubing and coupling to the intake vents of the big Kawasaki. The joint was carefully sealed with high-density foam.
So we could measure the pressures generated in the airbox as we pumped air up the ZX-9R's nostrils, a manometer, or pressure gauge, was plumbed into it. With the manometer we would be able to measure pressure up to 30 millibars above atmospheric pressure. A bar is roughly equivalent to atmospheric pressure; one millibar (mb) is just one thousandth-0.001-of a bar. Not a lot compared to tire pressures, but Steve's experience with varying boost levels on his 250-bhp turbo-which churns out approximately an extra five horsepower for every 70-millibar (one-psi) increase in boost or intake pressure-suggested that if it were possible to create one psi of pressure in the airbox, we could be looking at an increase of 5 to 6 bhp. Note that pressure, in the context of this article, is pressure above atmospheric pressure.
Burns' first thought was to set the air pressure at a certain level, say 15mb, and then measure the power at a steady throttle at 1000-rpm intervals. This was abandoned when we realized the results would be meaningless using CV carbs, which wouldn't necessarily be at full lift.
The second problem was that as the slides lift and the motor drags in air, the pressure in the box drops off. Observation suggested that if the airbox pressure was set to 10mb at idle, then at the redline, the manometer would show just 4mb. Obviously this bears little relation to real life, as the only way the airbox would be pressurized at idle would be if the bike were freewheeling down the highway.
Most importantly, the level of intake pressure on the road would be relative to the velocity of the motorcycle. If the airbox were pressurized to 20mb at 150 mph, it would be correspondingly less pressurized at 120 mph and still less at 70 mph. We had no way of reproducing this effect on the dyno, but if we could show that an air pressure of, say, 20mb gave a boost of 3 bhp at a certain point in the rev range and could then relate that to real road conditions, we'd have a fair idea of what the actual power output on the road would be.
In the longer term, Burns hopes to be able to use an interface between fan and dyno to take account of increasing air speed and thus simulate the effect of road speed on a static dyno.
FIRST TEST
The initial step was to run the Kawasaki at atmospheric pressure-no boost-to get a baseline figure. The ZX-9R, like others tested on the same facility, gave 123 bhp at its power peak. The induction fan was then connected, and the bike was run with the intake pressure set to 10mb at idle. The process was then repeated with 20 and 30mb of pressure. In each case the intake pressure fell by approximately 6mb at peak revs when the slides were fully up and the engine was gulping down great gobs of mixture.
The results were gratifyingly clear. At peak power the ZX-9R was producing an extra 2.6 bhp for every extra 10mb of pressure fed into it by the fan. Peak power was up from 123 bhp to 131 bhp, an extra 8 bhp over atmospheric pressure. A secondary bonus was that the bike also hung on to its peak better, which would translate into a more forgiving motor on the road, which would be less sensitive to gearing and thus more likely to be able to take advantage of following winds or favorable gradients to give a higher maximum speed. Because of the testing procedure we'd been forced to use, the graphs also showed similar increases right through the rev range, but this was obviously deceptive. There was no way that the levels of boost measured at low speed on the dyno could be reproduced on the road. At this point we suspected that boost would be insignificant at speeds below 100 mph.
INTERIM CONCLUSIONS
So far so good. The first part of the experiment was a success. We'd shown that pressurizing the ZX-9R's airbox definitely produced power increases. We'd established that the system has the potential to work, but what we didn't yet know was how the pressures we'd managed to generate on the dyno-a maximum of 30mb at idle, or 24mb at peak revs-related to real road conditions. Phase two was to attempt to establish what sort of pressures are actually generated in the Kawasaki's intake system at speed and relate them to the dyno results.
PHASE TWO
Had we been NASA or a top GP team, the next step would have been easy. Strap a datalogger to the bike, rent a private test strip and go play for a couple of days. We weren't, so the manometer was cunningly strapped to the gas tank, green food coloring added to the fluid for added visibility, and a portable datalogger-yours truly-mounted to the bars.
Just riding from the dyno facility to the strip was illuminating. We'd reckoned on needing 90 mph before boost would register, but at an indicated 70 mph the manometer already showed 8mb of boost.
At the strip we were able to give the big Kwakker its head, with one eye on the slowly rising column of green fluid and the other on the rapidly rising speedo. At the end of each run we logged boost pressure against indicated speed.
The results were even better than we'd hoped for. At lower speeds (under 120 mph) the gauge was easy to read and the results quite consistent: at 70 mph pressure was 8mb; at 80 mph, 10mb; at 100 mph, 12mb; at 110 mph, 14mb. From this point things really took off: At 120 mph (indicated) the airbox pressure was approximately 19mb, at 130 mph about 23mb, at 140 mph, 26mb and at an indicated 150 mph, the gauge was beginning to pump out green liquid as it bubbled over the 30mb limit.
At a real speed of 167 mph, past experience shows that the ZX-9R's speedo indicates 181 mph; there was obviously even more to come, perhaps as much as 30 mph worth of additional air pressure. Plotting the air pressure figures against speed for a rough representation of the way the air pressure increases suggests that the progression isn't linear.
This is as we'd expected. Air drag doesn't increase at a linear rate but relative to the square of the speed. At above 25 mph, air resistance builds in proportion to the square of the air speed over the motorcycle: twice the speed, four times the resistance. The faster the bike goes, the greater should be the increase in pressure and thus intake pressure. When we plotted the rough course of the pressure increase on a graph and continued it upward, we came up with a projected 44mb (or more) of pressure at an indicated 180 mph, when the bike would actually be traveling at its real top speed of 167 mph.
SO WHAT DOES IT MEAN?
The maximum pressure we were able to generate on the dyno was approximately 30mb, which gave a peak of 131 bhp from a ZX-9R as compared to the 123 bhp measured at rest. In other words, each 10mb increase in inlet pressure is worth approximately 2.6 bhp at peak on a derestricted 9R.
At an indicated 150 mph on the road, the inlet pressure had already neared the 30mb figure. We can therefore say with confidence that the ZX-9R is producing at least 131 bhp at the rear wheel in real world conditions-8 bhp more than at rest on the dyno.
Flat out, however, the Ninja indicates another 30 mph on the speedo. If boost at this speed was, as seems likely, 40mb, then the gain over atmospheric pressure would be approximately 11.5 bhp, giving a peak figure of 134.5 bhp. If inlet pressure reached 45mb, which it might well do, then the increase would be as much as 12 bhp, or a peak of 135 bhp. In other words, 123 bhp measured normally on a static Dynojet rolling road dynamometer could translate to as much as 135 bhp or more on the street. Ram air works.
An extra 12 bhp sounds like an extraordinary power gain for nothing except a bit of wind, but it's important to remember that at lower speeds the increases won't be as significant. Up to 120 mph when the boost hits 20mb, we're only talking about the odd bhp. From then on it gets progressively stronger. As the effect is speed relative, it's at its most pronounced at very high velocities; the faster you go, the stronger the boost. But, hey, how many of you ride at 150 mph on the street? Never mind, don't answer that.
Having said that, the effects of even small amounts of boost on throttle response haven't really been investigated and may help to explain some of the surging acceleration typical of big Kawasakis.
It does, however, clarify the impressive figures that Kawasakis deliver at the strip and explain why a ZX-7 putting out the same power as a GSX-R on a static dyno will romp away under speed testing. It also begs the question of when someone is going to bring out a fully functional aftermarket pressurized-intake system.
Finally, it explains why Honda's jewellike CBR600 has finally gone the ram-air route in its quest to head off the ZX-6R.
This story was originally published in the August 1995 issue of Sport Rider.
http://www.sportrider.com/tech/146_9508_ram/
V2K_CCTX:
2007 ZX-14 Ebony Black (his) -- Leo Vince exhaust/flies out/PC3 mapped/SS brake and clutch lines/helibars/Competition Werkes GP pegs F&R/Puig Carbon Fiber Windscreen/Bikelites fender eliminator/custom CNC frame sliders & fork sliders
2007 CBR600RR Pearl White/Silver (hers)
2007 GV650 Avitar (hers)
2007 Vulcan 2000 LT (his) Muzzy Drag Pipes/Kuryakyn ProR Hypercharger/PC3 mapped/Chrome everywhere/everything
2007 Ninja 250R Silver (daughters) w/ Muzzy SS Exhaust
BIGZXDADDY
posted August 02, 2007 09:06 PM
V2K don't screw up peoples dyno stories with facts. just kidding obviously as i think we are on the same page when it comes to supercharging, static or mechanical. also pulling the flies will not change the top end. if your flies are in and its not pulling hard enough it's because you are in the wrong gear or going too slow in first. that being said p/c is on it's way so i can pull those pesty "flies" and have even more fun
V2K_CCTX
posted August 03, 2007 07:27 AM
Sorry Big Daddy, no more facts. My ZX-14 came from the dealer with 300hp, and went to 400 when i pulled the flies, and 500 with a pipe and 600 with PC3 and and and...
And my fish was thiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiis biiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiig
LAMO
V2K_CCTX:
BIGZXDADDY
posted August 03, 2007 02:29 PM
thanks V2K! just trying to keep the peace you know.lol, so you caught one of those fish too?killer. very nice post by the way,thanks for good info. well my p/c came in today so guess what i,m doing tonight
Biggy_P
posted August 09, 2007 10:09 PM
Lies I tell You!! Lies
Yep, I got my HP info from Cycleworld. Should have known better... Anyway coming from my Tuono ( 130 RWHP V-twin) which does challenge grip strength (lots of low end torque) I expected much the same from the Z... The Z has been the very model of civilization and extremely smooth. Too smooth at times as I picked up my very first speeding ticket ever in 25 years (I'm 42) the second time I rode it. After arriving home I did what any repentant speeder would do: Promptly ordered a Two Bros exhaust and a PCIII.
'06 ZX-14
Stone Stock
'03 Aprilia Tuono
phytrax
posted August 10, 2007 08:51 AM        Edited By: phytrax on 10 Aug 2007 09:52
The power is still sneaky on a bike like this, the riding position sends a lot of the acceleration right to your butt so it feels nothing like car or cruiser would at the same acceleration. Also, how many cars or v-twins hit 85 mph in 1st gear?
KX450F - kickstand
0.2166600227356 seconds processing time
