BIKELAND > FORUMS > ZX-14.com > Thread: Advise for Prostar anyone? NEW TOPIC NEW POLL POST REPLY
jarhead
posted July 27, 2007 07:21 AM
Would appreciate any advise from some of you that have ran Pro Star in the past. I am kicking around the idea of racing the Indy race in Street ET and also the Real Street. Here's the problem, I talked to tech and they gave me a list of things to check. The one I am hung up on is the 3" clearance. I have Muzzy three hole links on the rear and they are set on the bottom hole (lowest). I have the fork tubes slid down so they are flush with the top of the mount and I am running a SS Muzzys pipe. It looks to me that even if I slid the forks back to the stock position I would still be too low. Oh yeah, I weigh 162 in shorts and I am on Shinko's front and rear. To me this rule does not make much sense. I understand they want to prevent oil downs from people coming down too hard from wheelies but I don't think raising a bike up, which makes it more wheelie prone is the solution. I race the bike as it sits with no problem with the front wheel coming up and can consistantly get 1.44-1.47 60's. I know this isn't great for a 64" bike but I am not leaving like a grandma either. Thanks.
chunter
posted July 27, 2007 07:33 AM
Hard fast rule, 3" ground clearance is needed for Real Street. If you have a sidewinder you can remove your lower qtr panels on the 14 to help gain some clearance. For a standard pipe the measurement will be at the lowest hard part, likely the exhaust header, for the 3".
Good luck and hope to see you there.
jarhead
posted July 27, 2007 07:45 AM
Do you know if the clearance is the same for Street ET?
chunter
posted July 27, 2007 09:39 AM
I think it's 2" in s/et.
posted July 27, 2007 08:07 PM
strap it with the stock suspension, maybe one hole down on the rear links.
mark524
posted July 27, 2007 09:32 PM
the rulebook is available in pdf on their website. it say 3" for streetbikes without wheelie bars with rider on the bike.
0.22705101966858 seconds processing time
